Old 10-26-2018, 08:25 PM   #1
5.9 Cummins Air Compressor Help
I have a 1999 TC2000 FE with 5.9 Cummins. Have had no issues with air brakes or air pressure since I bought it this spring. Always built pressure quickly - no leaks, no fluids in tanks, etc. All of a sudden, it won't build pressure above around 60. After reading various forums, I replaced the governor - with no change in symptoms. I have bled the tanks to 0, and it still builds to around 60 and stops. I have checked for leakage with engine running and stopped, and haven't found anything. I thought about maybe a clogged intake strainer, but can't figure out where one might be located. As far as I can tell the intake for the air compressor is connected to the engine intake manifold. Don't see any crimped hoses or lines. Any experienced input would be appreciated.
TrailLifeBill is offline   Reply With Quote
Old 10-26-2018, 10:45 PM   #2
Might test the gauge if all else looks right.
Old 10-27-2018, 06:27 AM   #3
Johnny Mullet's Avatar
Engine: T444E 7.3L
If the brakes release and are not dragging the it could be the gauge. If not and you replace the governer, then the compressor might need replaced.
Mullet's Thunder Bus Build
Old 10-27-2018, 07:24 AM   #4
Brakes won't release - was hoping it wasn't compressor since it does build pressure to 60 pretty quickly.
Old 12-19-2018, 10:54 AM   #5
Chassis: Tc2000
Engine: 5.9 24v
Rated Cap: 27
Sorry im not nay help but curious what the outcome will be. Learning about air systems
Jsneeb is offline   Reply With Quote
Old 12-19-2018, 11:19 AM   #6
Ronnie's Avatar
Engine: 345 international V-8
If it builds quickly then stops it is unlikely an air filter issue or even a compressor issue. If it builds up slowly with the last few pounds taking forever then I would say compressor.
On older stuff the governor can be set to your desired max pressure. Might want to look into that, also check the safety valve. In fact you may want to check the safety valve first, see if when you reach 60 psi if you hear air venting at or near your air tanks
