Old 12-14-2015, 06:50 PM   #1
Chassis: CSFE
Engine: 5.9 Cummins ISB
Rated Cap: 25
"5.9" cummins hot fuel smell when running
I have a 2002 Bluebird w/ a 5.9 Cummins. After it has been running a while I smell hot fuel fumes in the drivers area. Has anyone else experienced this before?
Eric A. Hinkley
railbus5 is offline   Reply With Quote
Old 12-14-2015, 07:29 PM   #2
Chassis: International 1753
Engine: 6.9 International
You probably got a leak somewhere. Spray the whole engine clean and drive it. Then look for leaks. There's rubber O-rings on the injector tubes that'll harden and leak. There's also rubber washers on every banjo bolt that will degrade and leak. Spray it down and start looking.
Old 12-14-2015, 08:47 PM   #3
2kool4skool's Avatar
I just chased and repaired leaks at all the O rings on the engine mtd fuel filter. The drain valve has 4, the water in fuel sensor was dribbling, the cover for the (optional) fuel warmer has 1also. And yes, check those sealing washers and the filter cover!
Don, Mary and Spooky the cat.
Old 12-14-2015, 09:35 PM   #4
Chassis: B3800 Short bus
Excessive piston blow-by can create a cloud of dieselly vapour smell around an engine as well. Sort of an exhaust + unburned diesel + oil smell.
Old 12-15-2015, 06:02 PM   #5
Chassis: CSFE
Rated Cap: 25
Thanks for the info.
Eric A. Hinkley
Old 12-15-2015, 06:04 PM   #6
Chassis: CSFE
Rated Cap: 25
Thank you. I will look.
Eric A. Hinkley
Old 12-15-2015, 06:07 PM   #7
Chassis: CSFE
Rated Cap: 25
I did some checking on the net and found that engines with high mileage have injector issues and can have low compression. I am fortunate to have a fairly low mileage engine. However it sat for probably 1 1/2 years being run very little. I will check and replace seals as this is the most likely cause. Thank you.
Eric A. Hinkley
