Old 09-20-2016, 01:48 PM   #1
Chassis: 1T8
Rated Cap: Dunno, big though.. Hauls
5.9 Cummins Tach stuck
Well, Cummins is new to me. 1997 Thomas. The tach is stuck in a position that it doesn't move. Any ideas?
TN Redneck is offline   Reply With Quote
Old 09-20-2016, 02:44 PM   #2
Chassis: TC2000 RE
Engine: 8.3l Cummins
The tachometer is driven off the alternator terminal (usually "w") and is not mechanical. Look to see if the electrical connection still works, or maybe the gauge is dead.
aaronsb is offline   Reply With Quote
Old 09-21-2016, 06:38 PM   #3
Chassis: 1T8
So if my alternator didn't work, the tach wouldn't either? Might have a charging problem...
Old 09-21-2016, 09:44 PM   #4
This may or may not apply. I've had luck with stuck meters being re set by using a powerful magnet to sweep the meter back into the zero position. A strong magnetic field will do the trick without even removing the gauge from the dash.
Old 10-06-2016, 11:45 AM   #5
Chassis: 1T8
Well, changed out the alternator, and no luck. Going to try the magnet trick, if that don't work, guess I need a new tach. Don't want to travel without one.
