Old 07-25-2017, 01:09 PM   #1
Dead pirate's Avatar
Coachwork: myself
Chassis: amtran
Engine: international dt466e allison md 3060
Rated Cap: 13 ton or so says the tit
5.9 engine pull
Any tips on pulling a 5.9 out of a carpenter flat nose front engine? My first one
Sent from my LGLS676 using Tapatalk
Dead pirate is offline   Reply With Quote
Old 07-25-2017, 01:47 PM   #2
Njsurf73's Avatar
Chassis: Bluebird
Engine: 5.9 Cummins 24v
Rated Cap: 72 pax
Are you trying to preserve the carpenter? If not I would think taking the glass, dash, and anything in the way out and yanking it with a motor lift. I am sure it will have to come out the front, but I think you will need to remove quite a bit anyway.
Old 07-25-2017, 02:40 PM   #3
Coachwork: myself
Chassis: amtran
I'm trying to save it. Just swap motors. It looks like it will come out the side door.
Old 07-25-2017, 03:36 PM   #4
turf's Avatar
i've been contemplating engine swaps on my bluebird.
i think if i remove the radiator, charge air, fan shroud, i could get a cherry picker in there without touching the dash or glass.
idk nothing about any carpenter!
post lots of pictures.
good luck
Turfmobile Build Thread
Old 07-25-2017, 05:01 PM   #5
Coachwork: myself
Chassis: amtran
Thanks
