Old 08-25-2018, 08:29 PM   #1
Chassis: Bluebird
Engine: Cummins 5.9L inline-6H
5.9 temp and oil psi
Took the bus cross country and was getting 55mph at 1700 with oil and temp sitting dead center. After a ton of reading got the tst power kit and replaced the fuel plate under the afc hoping to gain a few mph.
After install doing 60mph at 1700 however oil pressure running little over 65 (probably ok), and temp creeping past 210 which is a bit of a increase.
Anyone familiar with this and have a suggestion other then putting stock plate back in, woukd really like to cruise a bit faster but not up for damaging the bus. Seems I read a dozen places where people did this without issue.
Hazin is offline   Reply With Quote
Old 08-25-2018, 08:48 PM   #2
Coachwork: Goshen
Chassis: E350
Engine: 7.3 IDI
Have a pyrometer? I'm curious what EGTs are running. What was your typical temperature before the mods?
Oil pressure is fine... and honestly, 210F isn't anything to worry about... but if it was a substantial jump in what it used to run, I'd look into it. More then likely, EGTs are a good bit higher. Need to know what exhaust temp is running.
Old 08-25-2018, 09:03 PM   #3
180-190 is normal operating temps, 210 is not critical and I wouldn't worry about damaging anything unless it was sustained at better than 230. Even my bus will see 230 temps on hills if you stay in it.
Old 08-25-2018, 10:14 PM   #4
Chassis: Bluebird
50 and 180 seemed to be the normal on a 12 hour trip before. On a 30 minute trip now is 65 and 210.
I'll have to look into the other
Old 08-25-2018, 10:31 PM   #5
Year: 1954
Coachwork: wayne
Engine: cummins 12 valve
odd numbers
so the water temp gauge is showing higher temperatures and the oil pressure is higher too.
I would expect with a higher water temp, and the same engine rpm, the oil pressure would be lower.
Old 08-26-2018, 08:43 AM   #6
check your grounding for the gauges.. if the ground is bad, its possible that the oil PSI gauge is obtaining its reading with grounding through the temp sensor ..
I didnt see what transmission this has.. but if its an AT545 then the engine might run higher RPM against the converter stall thus creating a higher oil PSI.. (and a HOT transmission!).
Old 08-26-2018, 11:37 AM   #7
Chassis: Bluebird
Engine: 5.9 Cummins/Allison
Rated Cap: 74
It seems to me that 1700 rpm is substantially under red line and if so should not be causing a temp problem.My 5.9 runs a 2200 rpm all day long and even with a AT545 does not build engine heat and to avoid trans temp problems I built and installed a MONSTER trans cooler.
Gdog 5651 is offline   Reply With Quote
Old 08-26-2018, 11:42 AM   #8
Chassis: Bluebird
Rated Cap: 74
And after installing the pump plate it is likely over fueling somewhat causing higher EGT after modifying fuel system a pyrometer is always a good idea if not near mandatory.
Old 10-29-2018, 12:29 AM   #9
Year: 93
Coachwork: Corbiel
Rated Cap: 36 pass
Hi GD, I have a 36 pas 93 ford with 5.9 and 545. Seems I'm runin around 2200 rpm at 60, when I tie into a hill the rpm goes up and the speedo goes down. I'm told this is normal for the 545, I'm thinkin with your bigger bus this must be a bigger issue. What are your thoughts on improving fuel mileage?
Free Bird is offline   Reply With Quote
Old 10-29-2018, 06:56 AM   #10
Ronnie's Avatar
Engine: 345 international V-8
Anytime you change from the factory fuel setting you really must have an exhaust temp gauge. High egt's make for melted pistons.
1700 rpm's seems over geared for it. 2200-2300 is a nice cruising rpm for the 5.9. Do you know what your gear ratios are? and do you know what speed 2200rpm's would be if you had the power to get there?
