Rated Cap: 37,400 lbs GVWR
Is that Crown one of the ex-San Diego 40-foot pushers that had 8.3s in the back? Crown would make pretty much whatever the customers wanted (each bus was handbuilt and made to order), so it's possible that there were other 8.3 pushers made.
Crown also used the 8.3, by then called the CT or CTA, in the Series 2 pushers like mine, but those buses are a lot newer then the one you're wondering about.
And no, there never was a pancake underfloor 8.3 from Cummins. The mid-engine Crowns used the old 220 (no turbo) and 262, and the big 855 cu.in. monsters at 290 HP and up, but never a horizontal 8.3. Were oilpans even made for that configuration?
