Old 04-27-2010, 08:23 PM   #1
Engine: 5.9
Rated Cap: 45
89 Blue Bird 5.9 Gen 1 Cummins, Blown Head gasket
Hi,
I knew the bus had some issues, but found that the head gasket is leaking between 4 and 5 on the exhaust side.
Does anyone have experience changing the head gasket, or have a manual for the cummins? This is a flat nose bus, and access to the motor is great up top, but will be a challenge removing all the stuff required to remove the head.
Any advice is appreciated.
Thanks,
Glen
Apacheglen is offline   Reply With Quote
Old 05-20-2010, 11:38 PM   #2
Chassis: Ford B700
Engine: 5.9L Cummins
Re: 89 Blue Bird 5.9 Gen 1 Cummins, Blown Head gasket
Would the busses be affected by the dowel pin problem? I had thought it was only a problem with the rotary pumps and most busses have the inline?
Another thing everyone with the 5.9 and air brakes should check is the rear air compressor bolts. They tend to come loose and without this rear support it will crack the timing chain housing which is not a real simple cheap repair either.
kamoo is offline   Reply With Quote
Old 01-23-2011, 06:06 PM   #3
Engine: 5.9
Rated Cap: 45
Long Story,
The head was cracked too, so I found a 12 head with 7mm injector holes. The head was almost new (had receipts to prove it), with about 1 hour of use.
My block was OK, just under service limits, about .005". I did not have a way to shave the block, but the new head was nearly perfect. I pulled a valve, and did a seat inspection found it to excellent. Put the head back together...
The motor is back together, and runs well. I think I have all the air out of the cooling system.. The motor has great oil pressure about 35psi at idle, temp 170, and 60psi at 2300rpm.
The head seems OK, no leaks, the coolant doesn't pressurize.
There is one thing wrong, the engine warning light and buzzer comes on after about 5 minutes. Pressure, temp, and alt voltage are all excellent. The radiator has no pressure to speak of, the heaters in the rear work, so I beleive there is adequate coolant supply. It's about a 50/50 mix.
Any suggestions?
Thanks,
I'll have to get the the dowel inspection soon... but after the engine buzzer.
Advice on 8.2 Detroit Diesel Head Gasket busboy Detroit Diesel Drivetrain 3 08-30-2015 10:45 PM
Need advice - blown head gasket Hornbus International | Navistar Drivetrain 4 10-21-2010 10:48 PM
Expense of head gasket replacement on DT466? Locutus International | Navistar Drivetrain 0 02-22-2010 09:51 AM
blue bird cummins pump? The Wanderer Conversion General Discussions 9 02-28-2007 01:55 AM
HEAD GASKET FAILURES NEW FORD 6.0 mike Everything Else | General Skoolie Discussions 3 09-11-2006 07:20 AM
