07-16-2019, 02:18 PM
#21
Way to go man!
07-16-2019, 04:56 PM
#22
Originally Posted by Ernie's Autowerks
Went to a car wash and washed as well as I could. Found a steady drip in this small hose and Napa built a new one for $38. Getting ready to test drive now but fingers crossed.
We're rooting for you, man.
07-16-2019, 06:06 PM
#23
Chassis: TC RE
Engine: 8.3L
The suspense is killing me!!!!!!!
GaryC
07-16-2019, 06:35 PM
#24
Chassis: IH 3800, 8 window
Jeez, give him a chance to wrench it down, and top it off! [emoji6]
07-16-2019, 08:47 PM
#25
I hope that fixes it. That was a lot of oil splashing around!
While not good long-term, I found that gorilla tape helped me mend a hose when I was traveling - until I was able to get a replacement at the next O'Reilly's (they have bus parts for some nice reason!).
Journey on!!
- Roger (Dog.Rescuer)
07-17-2019, 12:30 PM
#26
Engine: 8.3 Cummins MD 3060
Thought I posted this yesterday but......the little tracker looks pretty bad......
2002 Bluebird All American RE 8.3 Cummins Allison MD3060. Located in Fulton MO.
07-17-2019, 12:35 PM
#27
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
poor little toad, at least it won't rust
07-17-2019, 12:41 PM
#28
And now time to officially finish this one off.....we made it home and a big thank you to the Skoolie.net community. After we got the hose replaced and tightened a couple bolts on the engine we hit the road and had zero problems for the next 850 miles and all the way home. We didn’t use any more oil or hydraulic fluid and cruised at 70 mph in 6th gear at 2050 rpm. Average fuel economy was 7.25 mpg. Fuel economy was certainly better in the 60-65 range but I was tired and just wanted to get home....thanks again!!!!
07-17-2019, 12:44 PM
#29
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
I bet home really looked good after that trip!
07-17-2019, 12:53 PM
#30
Coachwork: Me
Chassis: 2001 IC
Nice work Skoolie.net
#31
sweet!!! you made it home!!! *AND* you also gained some condifence in yourself and your rig!!! YOU fixed it and got it back on the road!! that rocks!!
07-17-2019, 07:15 PM
#32
Chilly legumes, and Well Done! [emoji106]
07-17-2019, 08:33 PM
#33
Chassis: CS RE
Engine: ISC 8.3 L 260 hp
Nice work! Getting a bus with 6th opened up is well worth dealing with an oil leak.
Ted
07-17-2019, 09:09 PM
#34
Rated Cap: 19
That first drive home in an unfamiliar bus is a nail-biter even if everything goes well so consider yourself properly initiated! I'm glad it was cheap and easy to fix and having #6 open is a real plus.
07-19-2019, 11:33 AM
#35
Engine: 8.3L Cummins Turbo
Rated Cap: 80
Same problem
I had the same problem with my 92 All American RE, only on the other side of the system at the reservoir. It effectively saturated my entire back windows of the bus and I would imagine anyone driving behind me. Easy fix though, replace all the hydro lines...like you had to.
D
D&J
1992 Blue Bird All American
8.3 L Cummins
07-19-2019, 01:13 PM
#36
Coachwork: IC/AMTRANS RE
Engine: T444E 7.3 w/ MD3060
Awesome-o u made it home. I was going to say I bet your tracker was well lubed, that will help that GM product to not rust away, just leave it on there HAHA.
Nice to read that orileys has bus stuff, I didn't know that but I will keep that in mind.
07-27-2019, 09:20 PM
#37
Coachwork: GILLIG
Chassis: G18E102R2
Engine: Cummins ISC 8.3
Rated Cap: 23 sits 33 stand
Most garages that service commercial trucks will have the ability to make up simple hoses or will know a shop that can. There also franchise businesses that do nothing but make commercial hoses. There are several here in the Dallas area. I got mine from the local GM dealer shop.
