Old 03-31-2019, 01:05 PM   #1
ultrapac's Avatar
Chassis: tc2000
Engine: cummins 5.9
92 bluebird wiper problem
So I'm trying to figure out why the passenger side wiper motor takes the wiper lower then the windshield seal
Like its lost its home switch or was not installed properly
The wiper arm can not be misaligned on the post
Just wandering if anyone knows anything about how these work
ultrapac is offline   Reply With Quote
Old 03-31-2019, 08:08 PM   #2
I only have experience with the Freightliner FS65 Thomad build. However, on t=our bus, the wiper arms attach to the wiper motor by sliding down a spline on the wiper motor shaft and a similar spline in the arm. Thus, there are a number of positions the blades can be set.
When I replaced my wiper arms, I did not get them on in the same position as they were originally set, so the driver blade did not rest the same place. To fix that, I loosened the nut, moved the arm away from the motor shaft until it cleared the splines, rotated the blade in the direction needed, and slipped it back down the wiper motor shaft.
Old 04-01-2019, 02:13 PM   #3
WARGEAR's Avatar
Coachwork: AmTran/Wolfington
Engine: International DT466E 190HP variant
Rated Cap: 72 pax 29500 GVWR
+1 on the arm having slipped its splines. If it gets knocked or weighed down too much by something it can happen. Just remove and realign!
WARGEAR is offline   Reply With Quote
Old 04-01-2019, 04:03 PM   #4
That might work if he hadn't said " The wiper arm can not be misaligned on the post"
Old 04-01-2019, 04:19 PM   #5
WARGEAR's Avatar
There must be some way to adjust them. No wiper system I’ve ever seen has been “one size fits all vehicles”. Perhaps the arm is merely bent?
