Go Back   School Bus Conversion Resources > Skoolie Tech > Mechanical and Drivetrains > Cummins Drivetrain
Click Here to Login
Old 06-09-2017, 09:16 PM   #1
97 bb 5.9 cummins all mechanical motor we overheated and on the side of the freeway
The coolant was a spewing out of the radiator cap that is on top of the overflow
Sunbear is offline   Reply With Quote
Old 06-09-2017, 09:23 PM   #2
Robin97396's Avatar
Do you know why it was getting that hot? Were you climbing a hill or something?
Robin
Nobody's Business
Old 06-09-2017, 09:54 PM   #3
Njsurf73's Avatar
Chassis: Bluebird
Engine: 5.9 Cummins 24v
Rated Cap: 72 pax
What kind of fan? Hydrolic? Belt?
Old 06-09-2017, 10:03 PM   #4
Hydraulic because I don't see a belt
Old 06-09-2017, 10:05 PM   #5
Njsurf73's Avatar
Chassis: Bluebird
Rated Cap: 72 pax
Ok what kind of bus? Fe,re, conventional?
Old 06-09-2017, 10:09 PM   #6
Njsurf73's Avatar
Chassis: Bluebird
Rated Cap: 72 pax
If it's hydrolic it will have 2 hoses to the fan motor. Follow them to the reservoir. It is likely an oil system (10w 30 on mine) and it should hold a good amount of oil (upwards of 3 gallons)
Start with the easiest thing, oil level in the fan (and usually power steering) hydrolic system.
Old 06-09-2017, 10:27 PM   #7
The power steering reservoir is the same best that cools our runs the fan motor it had been leaking on the top out of the vent but it days its almost full
She is a97 blubird with a 5.9 cummins all mechanical motor
Old 06-09-2017, 10:27 PM   #8
Dead pirate's Avatar
Coachwork: myself
Chassis: amtran
Engine: international dt466e allison md 3060
Rated Cap: 13 ton or so says the tit
Either the belt or the water pump. Describe how it over heated
Sent from my LGLS676 using Tapatalk
Dead pirate is offline   Reply With Quote
Old 06-09-2017, 10:29 PM   #9
Njsurf73's Avatar
Chassis: Bluebird
Rated Cap: 72 pax
Ok. How about a few pictures
Old 06-10-2017, 01:30 AM   #10
Made it to a friends place
She was only 3 quarts water and it was full the fan turned and the water pump seemed to be pumping I drove.her 55 miles per hour about 25 miles and the gauge did its usual up and down thing but never got any where near the red. I still have 2100 miles to go and I'm afraid to get in the middle of bum **** Wyoming our idaho and have it happen again I'm going to replace the radiator cap but what other kind of tests or trouble shooting can I do?
Old 06-10-2017, 06:21 AM   #11
Njsurf73's Avatar
Chassis: Bluebird
Rated Cap: 72 pax
If it is a hydrolic fan, it may turn, but there is a type of diverter valve that will preference your steering before your fan. If the pressure drops low for some reason it won't fully engage the fan... That being said I have very little knowledge of testing this system.
