Old 06-26-2018, 08:34 AM   #1
Brewerbob's Avatar
'99 B.B., 8.3L Cummins w/ MT643 Tranny heat exchanger
Does anyone know what the part numbers are for the water inlet tubes and tranny heat exchanger? I believe my heat exchanger is shot. The metal water inlet and outlet are rusty as hell too so might as well replace those while under there.
About the transmission fluid, it's red like ATF but it doesn't stink. Is bus tranny fluid different? Sounds like the same old stuff that Auto Zone and the like carry.
Originally Posted by FSM
Approved Hydraulic Fluids
! Automatic Transmission Fluid Dextron
II
! Automatic Transmission Fluid Type "E"
or "F"
! Chevron 10W-40 Motor Oil
! Chevron Custom 10W-40 Motor Oil
! Chevron Torque 5 Fluid
! Exxon Nuto H32 Hydraulic Fluid
! Fleetrite PSF (Can #990625C2)
! Ford Spec M2C138CJ
! Mack EO-K2 Engine Oil
! Mobil ATf 210
! Mobil Super 10W-40 Motor Oil
! Premium Blue 2000 – SAE 15W-40
! Texaco 10W-40 Motor Oil
! Texaco TL-1833 Power Steering Fluid
! Union 10W-40 Motor Oil
! Union 15W-40 Motor Oil
! Unocal Guardol 15W-40 Motor Oil
Old 06-26-2018, 08:54 AM   #2
most all of the allisons "standard" fluid is good ole DEXRON III like the old GM's used..
TES-295 fluids like Transynd are probably the best (but also expensive).. and as listed on the above list, certain motor oils (C4 designated) are acceptable.. the motor oils tended to stand up to heat better than regule ole ATF.. and the synthetics didnt exist when a lot of these Spec's were written.. 643s have been around a long time..
Old 06-26-2018, 09:08 AM   #3
Brewerbob's Avatar
The hydraulic reservoir has a 15-40 oil weight sticker on it. I'm not certain on the exact weight; I have a picture of it somewhere. But the question is is that oil or tranny fluid? This is red like good old Dextron. Does this mean I'm running oil for the engine and tranny fluid? Oil isn't red. Seems odd that they would use two different fluids if regular old oil is approved for both.
Tranny fluid is nastier to get rid of (EPA), costs more (I think), and you'd have to have two different storage containers.
Old 06-26-2018, 11:55 AM   #4
Brewerbob's Avatar
Part # 00103804
List: $875.60
Wholesale: $616.90
Yeah,... that's not happening. So, who knows someone that knows someone?
