Old 05-21-2016, 08:34 PM   #11
Coachwork: IC
Chassis: CE300
Rated Cap: 32
yeah I think you are right mine is a Bosch.. ive had several people tell me they like my bosch because it can safely be turned up and the timing advanced a few degress on the DT360 / 466 without worry of over-temping the exhaust..
The p pump is another bosch.
Roll Your Own Build Thread
Old 05-21-2016, 08:36 PM   #12
Chassis: International S3800
seems like bosch to fuel systems is kind of like bendix to air brakes...
do cats and mercedes busses use bosch too?
Old 05-21-2016, 08:59 PM   #13
crazycal's Avatar
I think the P-pump is from about 1994-1998 on both Cummins and International engines. I think EC is right about it being a different Bosch pump.
I'm hungry!
You Gotta Let Me Fly
Old 05-22-2016, 10:56 AM   #14
rjnye79's Avatar
Engine: T444e
Speaking of these Cummins 5.9s... Anyone have experience with the killer dowel pin?
rjnye79 is offline   Reply With Quote
Old 05-22-2016, 11:01 AM   #15
Got mine taken care of before installing the engine. Couple of ways to go about it. Buy or make a tab that is screwed into a hole next to it...or just peen the edge of the hole the KDP is in. That's the route I wet since the screw & tab just seemed to be more two more things that could wind up in the timing gears.
Either way, if you have a model with that issue...it needs to be addressed.
Old 05-22-2016, 02:19 PM   #16
Robin97396's Avatar
That's an awkward procedure in a FE. Thanks for the peening idea Tango.
That sounds most reasonable, since the tab and bold are two additional possible problems. Not to mention the fact that I read somewhere the tab and bolt are about $50.
5.9, cummins, engine, p pump
