Old 05-21-2016, 09:31 AM   #1
rjnye79's Avatar
Engine: T444e
Question A P-Pump?
Good morning folks!
Just curious... what is a p-pump and how do you feel about it with the Cummins 5.9?
rjnye79 is offline   Reply With Quote
Old 05-21-2016, 09:40 AM   #2
Originally Posted by rjnye79 View Post
Good morning folks!
They're what you want.
Roll Your Own Build Thread
Old 05-21-2016, 10:15 AM   #3
Absolutely. All 12-valve Cummins are non-electronic and the inline Bosch pump is the number one choice for a whole host of reasons. Here is a little blurb from a Cummins blog...
The 1994 - 1998 Engines offer good power and torque, as well as good fuel economy. These engines have the Bosch P7100 inline manual fuel pump which produces 160-215HP stock. With this pump, one can easily add 15-95HP by installing a fuel plate. These engines are possibly the most desirable 12-Valves because power upgrades are easily accomplished with fuel plate adjustments etc. If you get an extremely good deal on an earlier engine it may be cost effective to convert it to a P7100 pump if your desire is big Torque numbers.
There are many power upgrades that can be done to any of the 12-Valve engines without totally sacrificing fuel economy or reliability.
Old 05-21-2016, 02:11 PM   #4
crazycal's Avatar
As SnoopDog would say, "They are the shiznit of IPs."
I'm hungry!
You Gotta Let Me Fly
Old 05-21-2016, 04:19 PM   #5
rjnye79's Avatar
Engine: T444e
Is the 5.9 Cummins desirable, regardless of the p-pump?
Old 05-21-2016, 05:07 PM   #6
Robin97396's Avatar
There is a 53 block that is known to have problems if you tend to overheat it much. Other than that they're pretty good. Preferences are varied as you might expect. As for the 5.9, if there's not a 53 on the block just under the IP you're good. The other marking on the block from Mexico I believe is kind of garbled and longer than 53. There was a discussion on this just a couple days ago.
Old 05-21-2016, 06:55 PM   #7
rjnye79's Avatar
Engine: T444e
I'm a jackass... what's the IP? ...also, the "53" is obvious?
Old 05-21-2016, 06:58 PM   #8
is a P-pump similar to what my mechanical DT360 has even though im IHC and not cummins?
Old 05-21-2016, 07:53 PM   #9
I think its a Bosch MW pump. I've been wrong before though.
Old 05-21-2016, 07:57 PM   #10
yeah I think you are right mine is a Bosch.. ive had several people tell me they like my bosch because it can safely be turned up and the timing advanced a few degress on the DT360 / 466 without worry of over-temping the exhaust..
5.9, cummins, engine, p pump
