Old 01-16-2018, 05:23 PM   #1
Chassis: Saf-T-Liner MVP ER
Allison Transmission Controller Question
There isn't a sub-forum, so I'm putting this here.
There are two different electronic controllers for the Allison transmissions (the ones with the push buttons).
The earlier one has a single LED digit showing gear range selected.
The later one has two digits, one showing the range selected, and the other showing gear achieved.
Does anyone know if they are interchangeable?
Steve Bracken
Build Thread
Old 01-16-2018, 05:31 PM   #2
joeblack5's Avatar
Year: 98
i do not think so, the single digit is a wtec 3.
the double digit is gen 4 and 5. Do you need one? I have a spare single digit.
since mine is wtec 3. The tcm is separate and should read
"tid3" on it.
later j
Old 01-16-2018, 05:34 PM   #3
"tid3" on it.
later j
Mine is working fine, I was just wondering if there was an easy upgrade.
I haven't dug far enough into the bus to get the numbers off the transmission. Bus was manufactured in May '98. I don't know when Allison switched models.
Steve Bracken
Build Thread
Old 01-16-2018, 05:39 PM   #4
joeblack5's Avatar
Year: 98
The tid3 is representative of generation 3. It will be also written on the transmission tag.
Old 01-16-2018, 05:46 PM   #5
Is the TCM attached to the transmission, and if so, what is the large box behind the dash that the controller wires into?
Steve Bracken
Build Thread
Old 01-16-2018, 05:52 PM   #6
joeblack5's Avatar
Year: 98
The tcm is most likely not attched to the transmission. Mine is next to the driver seat. It has 3 connectors and an allison lable.
Old 01-16-2018, 05:54 PM   #7
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
That's for Kleenex. You can remove it.
Old 01-16-2018, 06:14 PM   #8
On it Rusty. I'm sure I'll have you to thank for the weight saving.
Steve Bracken
Build Thread
