Old 09-26-2017, 12:21 AM   #1
Year: 1972
Engine: Cummins NH220
Any advice on where to service a cummins 220 (crown 1972) in the Bay Area?
Anyone know a good shop (or a good guy) for a crown 1972 / cummins 220 in the bay area?
I have an oil leak I'd like to have checked out.
Thanks!
hanaiapa is offline   Reply With Quote
Old 09-26-2017, 08:54 PM   #2
Rivetboy's Avatar
Oil leak
I do not know any mechanics. Sorry
I would suggest gunking the motor and pressure wash it so it is reasonably clean.
Then start it up and crawl under with a flashlight and see if you can determine where the leak is from. There is a 3 inch by 24 inch lifter cover under the injector pump and that gasket is the culprit in many instance when you have a huge oil leak in a hurry. Front and rear seals drip.
It is a big job due to access issues but calling around for estimates when you describe it accurately will get you more estimates.
Rivetboy is offline   Reply With Quote
