Old 07-25-2016, 04:35 PM   #1
Engine: 5.9L Cummins
Apparently my alternator is shot... a few questions HELP ASAP!
So I have a 2000 Bluebird TC2000. 5.9 cummins.
The mechanic just told me my alternator was about 1 mile from blowing up (ie. bearing was super loose.
I expect that with such a common engine, the alternator should be a quick/cheap swap. Apparently its larger commercial unit and there are none in my city.
Would a regular alternator for a dodge cummins 5.9L work?
Im wanting to take my bus on a trip this friday....
-cycosis- is offline   Reply With Quote
Old 07-25-2016, 06:41 PM   #2
Chassis: IH
I would hazard to guess "Probably not", if for no other reason than the wiring hooks up differently. Different plug styles, internally regulated/externally regulated, different electrical ratings ...
Old 07-25-2016, 07:05 PM   #3
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Should be available at a truck stop, or repair shop.
Old 07-25-2016, 08:02 PM   #4
Anyone know what type of alternator I should be looking for and what a fair price is?
Old 07-25-2016, 08:14 PM   #5
Chassis: AARE
Show pictures, including electrical connections and mounts.
Old 07-25-2016, 08:52 PM   #6
2kool4skool's Avatar
https://www.amazon.com/DB-Electrical.../dp/B0081SC7WM
Here's a pic of ours:
Delco 28SI
http://www.delcoremy.com/Alternators...el-Family/28SI
Don, Mary and Spooky the cat.
Old 07-25-2016, 11:02 PM   #7
At least match the amps of your original. Might be around 140? More is better.
Old 07-26-2016, 01:25 AM   #8
Have you tried running the numbers on the label through a search engine . Considered a rebuild kit as long as your semi mechanical not to difficult to rebuild one .
https://www.amazon.com/ALTERNATOR-BL.../dp/B008HTUHRW
103.94 Sounds about correct
Progress doesn't come from early risers — progress is made by lazy men looking for easier ways to do things.
mad_wolf is offline   Reply With Quote
Old 07-26-2016, 06:52 AM   #9
Chassis: AARE
If a bearing is noisy why don't you simply replace the bearing, it's not all that hard. Mechanics these days don't seem to want to repair anything. I know for a fact that whatever alternator you have, it's not that all that hard to do. The bearings are also not all that hard to come by any place that sells bearings should have them on the shelf. (like Bearings Inc) While you're in there replace the brush assy.
Note, I did recently come across an alternator that I couldn't replace the bearings in. It was an Italian alternator (Marelli) on my British car (Land Rover). It was manufactured in such a way that you couldn't get the housings apart.
You probably have a J180 mount which was pretty much everything until the last few years. If it has one long bolt going through two ears and one ear on the opposite side it's probably a J180. There are only two variations, the distance between the upper and lower bolt is different. On many engines they will interchange. With a J180 mount usually the belt is tensioned by swinging the alternator, but it may have a fixed mount with a separate tensioner.
The picture that 2kool4skool posted is a J180 mount.
There are many manufacturers of heavy duty alternators, Delco, Leece-Nevile, Bosch, etc. The main difference is amps and the later ones like the Delco 28SI are for high underhood temp problems.
A pad mount alternator is bolted to the engine with four bolts and uses a separate tensioner.
Dick
Old 07-26-2016, 10:27 AM   #10
Thx for the info
Old 07-26-2016, 01:36 PM   #11
turf's Avatar
just out of curiosity i checked in my cummins quikserve for the alternator on my 5.9, and they don't list one.
im also curious if you change that from the bottom, top or front? post pics when you get it sorted out.
Turfmobile Build Thread
Old 07-26-2016, 02:31 PM   #12
It is probably like many other such parts...speced by the chassis manufacturer...not Cummins.
