Old 08-12-2019, 01:03 PM   #1
Chassis: Saf T Liner MVP EF
Engine: 5.9 24 Valve / AT545
AT545 What Trans fluid do you recommend?
Hey all,
I have looked through most posts regarding the AT545 and I haven't saw what type or kind of trans fluid people are using. I will be adding a cooler and changing the fluid and filters and was curious what people have been using.
Matl0c is offline   Reply With Quote
Old 08-12-2019, 01:07 PM   #2
Mine had a fresh change when I picked it up but I'll be draining it and refilling with Transynd. The standard stuff for a 545 is dex 3.
Old 08-12-2019, 01:21 PM   #3
Thanks! I am thinking the same
Old 08-12-2019, 01:28 PM   #4
Its around $45-$55 a gallon but its synthetic. In Fl it actually says in the school bus regulations and that all school buses must run transynd.
I got a cooler from Tango that he didn't need and plan to install it when I do the fluid change. Its a beefy unit made by Earls. He made me a deal on it but new they're around $400.
Old 08-12-2019, 01:35 PM   #5
I got a pretty decent deal on this cooler from a local shop I used to deal with. Should work for me.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 08-12-2019, 04:30 PM   #6
Chassis: International 1753
Engine: 6.9 International
Like charlie said, dexron 3 was the standard fill ages ago.
I recommend sticking with it. It's good enough for the job and you can get it from almost anywhere (parts store, hardware, grocery, gas station, etc.)
Transynd is a great fluid. It's a premium synthetic which will last many many miles and run cooler doing it. But for most, it's not necessary and just wasted money.
Some people have used John Deere hy-gard hydraulic fluid. I've never done it so I can't recommend it.
Some districts even used engine oil with allison's blessing
Old 08-12-2019, 07:07 PM   #7
Johnny Mullet's Avatar
Engine: T444E 7.3L
I used standard Dextron/Mercon with some Lucas in mine. Video How To here........
Old 08-13-2019, 12:44 PM   #8
Thanks for the help! Should be installing the additional cooler this week and changing the fluid
