Old 08-27-2017, 10:09 AM   #1
Rivetboy's Avatar
Bellhousing / rear engine mount Cummins 5.9
I want to replace the rear engine mounts on my 1991 Bluebird tc2000 Cummins 5.9 /Allison 545 and am having no luck finding them. On the Cummins quick serve illustration of the bellhousing it does not show them. The front mount was no problem.
Maybe I am searching for the wrong term.
Has anyone else been able to find them or know what the correct noun nomenclature is?
Thanks
RB
Rivetboy is offline   Reply With Quote
Old 08-29-2017, 07:17 AM   #2
Rivetboy's Avatar
Cummins Quick serve is your freind
Looking deeper and in in different section I am under the impression that the bellhousing mounts bolt directly to angle brackets.
Who knew? I sure did not.
Old 08-29-2017, 08:19 AM   #3
2kool4skool's Avatar
I believe they're called pads.
Don, Mary and Spooky the cat.
2kool4skool is online now   Reply With Quote
Old 09-02-2017, 06:20 PM   #4
Rivetboy's Avatar
Hah thank you I was under the bus today and that is just what they look like.
Now to find them so they can be ordered.
Old 08-13-2019, 03:53 PM   #5
Chassis: Saf T Liner MVP EF
Engine: 5.9 24 Valve / AT545
Were you ever able to find these? Did it make a big difference?
Matl0c is offline   Reply With Quote
Old 08-16-2019, 02:16 PM   #6
Rivetboy's Avatar
Yes it did. My front mount was wasted so i pressed in a new one there also. Night and day with vibration issues. I bought the trans mount from some bus supply house, the front one from Cummins.
