Old 04-01-2017, 10:02 AM   #1
Question Big Honkin air filter.
Hello, Will this replace my 97 stock 5.9 12v air filter?
AFE 21-90058 Pro Dry S BHAF (Big Honkin' Air Filter)
Old 04-01-2017, 08:07 PM   #2
turf's Avatar
the napa filter for my '93 blue bird 5.9 is this guy. you can compare measurements
https://www.napaonline.com/en/p/FIL6500
Turfmobile Build Thread
Old 04-01-2017, 08:18 PM   #3
Probably the two most important air filter numbers are...
1. Particle size (in microns)...and...
2. CFM (Cubic feet per minute of flow)
Big is good, but unless the flow rate is adequate for your engine it will run fat and sluggish.
Best to check factory specs.
A good example of particle size vs flow issues are the K&N units that so many rodders love. They love'em because they have very high flow (cool). They flow at a very high rate because they don't stop much of anything from getting into your engine (not cool).
Match the right flow rate and particle size for a long lived, happy motor.
Old 04-02-2017, 09:00 AM   #4
Thanks. Yours is quite a bit taller etc.
Old 04-03-2017, 01:31 PM   #5
turf's Avatar
what price are you seeing on that link?
yesterday it was $72, today its $40?
edit:
arrrgh, i tried to buy it and it showed up in my basket at $72
try this link:
Luber-finerĀ®, Built to do More - Heavy Duty Products
Old 04-03-2017, 03:41 PM   #6
Robin97396's Avatar
Try this.
https://www.amazon.com/Luber-finer-L.../dp/B0049LP3SA
Robin
Nobody's Business
Old 04-03-2017, 03:55 PM   #7
Robin97396's Avatar
Here's a few more.
https://www.grainger.com/product/LUB...-Filter-36DD50
Luber-Finer LAF2523 Air Filter NEW OPEN BOX | eBay
http://www.opticatonline.com/part/lu...523-air-filter
https://www.zoro.com/luberfiner-air-...23/i/G9776794/
https://www.newegg.com/Product/Produ...9SIA5D52YU9950
https://www.carid.com/fram/air-filter-mpn-laf2523.html
Walmart used to carry this filter but it has been discontinued. On average most are $35 to $40 +or- shipping.
Robin
Nobody's Business
Old 04-03-2017, 07:29 PM   #8
turf's Avatar
Thanks Robin!
i scored 2 fuel filters, an oil filter, and an air filter delivered for $62.
Old 04-03-2017, 09:39 PM   #9
Robin97396's Avatar
Cool. That was a learning experience for me too.
Robin
Nobody's Business
Old 04-04-2017, 08:30 AM   #10
Thanks Robin. I was reading about 5.9's on the Cummins Forum of the Dodge Diesel forum and they talk about using a filter called Big Honkin Airfilters to use on Dodge trucks. Can't find it know but i read you can gain 15 hp with one.
