Old 08-05-2017, 12:13 PM   #1
Dead pirate's Avatar
Coachwork: myself
Chassis: amtran
Engine: international dt466e allison md 3060
Rated Cap: 13 ton or so says the tit
Cheapest route.
I'm at a camp ground ($30 a night) town and a mechanic is 10 miles away. I don't know what to do
Sent from my LGLS676 using Tapatalk
Dead pirate is offline   Reply With Quote
Old 08-05-2017, 12:33 PM   #2
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
What's your point?
Old 08-05-2017, 01:00 PM   #3
Coachwork: myself
Chassis: amtran
Point? Im riffing for ideas. I guess you don't have any
Old 08-05-2017, 01:47 PM   #4
Skipoffools's Avatar
Coachwork: Carpenter (Cavalier)
Chassis: International Harvester
Engine: DTA360
Rated Cap: 63
It might help to further explain your dilemma so we can help. What do you need a mechanic for?
Skipoffools is offline   Reply With Quote
Old 08-05-2017, 01:50 PM   #5
Coachwork: myself
Chassis: amtran
At this point I'm trying to assess possible damage to valves caused by a bent push rod. Can the valves ever hit the piston on a 5.9 cummins 12 valve? And I'm weighing a mechanic verses a tow.
Old 08-05-2017, 03:40 PM   #6
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
They are interference engines. However, since it has a positive gear drive (as opposed to chain or belt drive)the problem does not occur unless the valve is held open from other causes....
what block # is it? Did you do KDP fix Killer Dowel Pin?
more info
Old 08-05-2017, 03:58 PM   #7
Coachwork: myself
Chassis: amtran
I did not do the kdp. I hope it is not an additional problem.
