Old 03-21-2011, 10:29 AM   #1
frank-id's Avatar
Re: clutch parts are every place
Normally the clutch that is used is a single disc 17 inch assembly. But first the engine must be known, single or dual disc and push or pull type clutch. After removing the bottom cover on the transmission, some information can be discovered. The early buses had a high failure rate because of many factors. No matter the present clutch system, changing to a dual clutch is a great upgrade and will work for a very long time. Making clutchless shifts is also a good clutch saver and more fun driving................Frank
International spicer clutch replacement rex_1_mn International | Navistar Drivetrain 5 01-27-2013 07:09 PM
Stuck clutch? 83 GMC 6000 4tf Cat w/ 302a frank-id Mechanical and Drivetrains 0 11-19-2012 12:34 PM
Parts Sale - Cleaning out my bus parts! syke Classifieds | Buy, Sell, Swap 2 07-13-2011 05:43 PM
Parts parts sources? frank-id Everything Else | General Skoolie Discussions 1 09-08-2006 09:34 PM
WANTED -- Clutch master cylinder for 1968 Intl Loadstar 1600 girlcabbie Classifieds | Buy, Sell, Swap 1 05-06-2005 10:56 AM
