Old 07-11-2017, 08:51 PM   #1
natedlee's Avatar
Engine: Cummins 5,9 12V
Rated Cap: 24 seats, 3 wheelchairs
Cooling system woes
I'm on the road in my 1998 Blue Bird TC2000 W/ Cummins 5.9 12v and I'm running into a couple issues.
1) My fan clutch isn't being triggered: so I assume a temp sensor is bad.
- I know the clutch works bc I tore down the front to replace it and found the wires had been ripped out.
- my dash temp gauge works, so I'm assuming there are 2 temp gauges?
2) Coolant leak: I suspect this red cylinder thing, but I'm not sure what it is. I noticed some coolant dripping today and found that this red cylinder thing next to my front steps (right if engine) is somehow involved. It's wet on top, which seems strange. Is it part of a heating system that was taken out?
3) My coolant dashlight is always on: This started after I took everything out for the fan clutch. At first it was inconsistent, but now it's solidly on. Coolant reservoir is totally full. I've ignored this light, but I'm unsure if it's involved with the above stuff.
We're planning to drive back home from CO to MD Thur so wasn't sure is I was heading into danger. Thanks!
natedlee is offline   Reply With Quote
Old 07-11-2017, 11:37 PM   #2
Coachwork: integral
Rated Cap: 37,400 lbs GVWR
The red thing is a cylinder of ether for a Quick Start ether injection system, for better starting in cold weather. You may have a button or switch near the start key for triggering it if needed. Unless you live somewhere really cold, you probably won't need it. I have this system on my bus (it was originally in service in the California Sierras), but I don't plan on buying another cylinder of ether for it - a block heater is a better way to start in cold weather.
Your coolant leak may be unrelated to the Quick Start system, unless it's leaking from the QS's temperature switch which is probably somewhere in the engine block, maybe near the thermostat housing.
Sometimes the Low Coolant Level sensor in the surge tank needs to be cleaned, and sometimes they fail altogether. It's probably a sensor with two wires, near the bottom of the surge tank. Drain the coolant, take it out and clean it, then check it - replace it if it doesn't work right because it's important! Its second wire is a ground: check every ground connection on the whole bus, because they can give you false alarms (or worse).
Old 07-11-2017, 11:43 PM   #3
John,
You are a wealth of good information.
Thank you.
Old 07-11-2017, 11:55 PM   #4
Chassis: IH
Second on the ether tank. I'd remove it. The coolant has to be coming from somewhere, you'll have to track down the leak and go from there.
The low coolant light will be an important fix as not only will you need to know if the coolant really is low (or not) but it often ties into other systems and on some computers they will not go into normal mode (when warmed up); they will remain in "warm up" mode indefinitely. This can mess with emissions and more importantly, fuel economy.
Old 07-12-2017, 01:15 AM   #5
turf's Avatar
the leak looks like the area of the water pump. i'd check those bolts for being loose. tighten all hose clamps. have you bled the air out of the system? there is a little hose and valve near the radiator cap to bleed the air out until you get a steady flow of coolant. air pockets can keep the water from circulating well.
Turfmobile Build Thread
Old 07-12-2017, 08:28 AM   #6
2kool4skool's Avatar
Yes, check everywhere: Rad cap, all bolts, all hoses and clamps. I had a small leak that after a few months turned out to be the rad. itself. Had to pull it, took to an expert to verify. I got a hand pressure set up to pump up the cooling system so I could check it without running every time to build pressure. Here's the bleed instr.
Don, Mary and Spooky the cat.
Old 07-12-2017, 10:46 AM   #7
natedlee's Avatar
It doesn't appear I have the bleeder valve. Jk just the overflow hose and the green hose.
Old 07-12-2017, 10:53 AM   #8
turf's Avatar
i'd almost bet you that one of those tubes in both pictures is your bleeder tube. look for that brass valve in the diagram. the tube should be end within a foot or so of the radiator cap.
Old 07-12-2017, 01:24 PM   #9
I dont have a cummins but on my red bus the bleeder valve is up high on one of the heater hoses a couple feet from the engine.
Old 07-12-2017, 01:49 PM   #10
Mine is, looking from the front, to the left side of the rad. cap. It was tucked back in there and hiding Also, you have no sight glass on the deaeration tank. Easy to replace.
Of the 2 hoses in your pic, the hard one is the bleed, that other is a washer hose.
