10-03-2017, 12:25 PM
Coachwork: myself
Chassis: amtran
Engine: international dt466e allison md 3060
Rated Cap: 13 ton or so says the tit
Cruise control and 6th gear
I have a 1998 international 3900 and was curious about a 6 th gear and how to turn the Cruise control back on. As in; is there anyone with the software and such? I'm in delaware at the moment.
Sent from my LG-LS777 using Tapatalk
10-03-2017, 01:37 PM
if its Navistar I can turn on the cruise control.. i have the software and hardware.. 6th gear is only readily available on an MD-3060 (requires hoops) or a 2006 and newer allison 2000 (unlessyou want to mod the valve body and swap the TCM).
10-03-2017, 04:27 PM
Coachwork: myself
Chassis: amtran
You are in ohio?
10-03-2017, 04:34 PM
Chris is DEFINITELY the expert on these things!
10-03-2017, 04:57 PM
Originally Posted by Dead pirate
You are in ohio?
yeah im in ohio.. I have sent my Nexiq device out to forum members before, i use it fairly regularly but if I get it back in a few days im happy.
EC - ha ive still got a TON to learn about this stuff!!
10-03-2017, 04:58 PM
You're miles ahead of 99.9% of us!
10-03-2017, 05:00 PM
Chassis: Ford B600
Rated Cap: 20 person
Amen to that, I want to know1/10th of what he does!
"Living Our Own Story"
The Bowser Journal
Watch our adventures by subscribing...
Youtube - bit.ly/TheBowserJournal
10-03-2017, 05:23 PM
Coachwork: myself
Chassis: amtran
Id love to borrow it. Does that come with a quick tutorial? I will return it prompt
10-03-2017, 07:20 PM
which engine do you have?
Navistar ServiceMaxx J1708 software is free, when you open it up and connect it to your bus.. you go to the 'Parameters" and it will show you what you can change.. some of them have a little help blurb.
I have a call wsith navstar in the AM to see about altering my trans and OSS type and maybe the HP upgrade.. once im off of that I'll know if Ill not need the device right away and can send it your way.
10-03-2017, 07:22 PM
Coachwork: myself
Chassis: amtran
I could but the connector if the software is free. How do i tell which motor?
10-03-2017, 07:26 PM
what year and kind of bus do you have? if you look under the hood there is usually a tag on the engine that says '7.6 liter', or on the side of the hood 'T-444E'(on the outside), etc..
the connector is $700.. thats why I share and send it to people to hopefully save them from that pain!
10-03-2017, 07:29 PM
Coachwork: myself
Chassis: amtran
10-03-2017, 07:30 PM
Coachwork: myself
Chassis: amtran
Push
10-03-2017, 07:40 PM
so you probably have a DT-466E? inline 6 cylinder engine with a big computer hanging off the near top driver side?
10-03-2017, 07:41 PM
Coachwork: myself
Chassis: amtran
Yup
Coachwork: myself
Chassis: amtran
Passenger side back wall for the fuse box/ computer
10-08-2017, 09:34 AM
Coachwork: myself
Chassis: amtran
Just checking back on the computer you might loan, but i want to make sure i know which engine i have first. How can i best fond that out
10-08-2017, 09:49 AM
if you have an international, you can take the VIN fro mthe chassis , call an international dealer and they will tell you anything about it.. engine, trans, rear gear ratio, etc. . you can also look for tags on or around the engine that may show what it is..
and you can take your VIN and run it through an online VIN decoder which will give you some info.. usually enough to figure out the engine type.
if the chassis is a ford or freightliner, I know i dont have the scan tools to work on those.. at least not the software.. though the hardware interface will.
10-08-2017, 09:51 AM
Coachwork: myself
Chassis: amtran
Its an amtran. Im going to check the chin decoder. Thanks
10-08-2017, 09:57 AM
Coachwork: myself
Chassis: amtran
The chin decoder says its a DT 466/ maxforceDT
