Old 06-15-2018, 03:35 PM   #1
Chassis: TC 2000
Cummins 5.9 12v crank no start no fuel
Okay I ran to the gas station and filled up all the fuel cans I had and put 10 gallons in. I opened up the bleeder valve on top of the fuel filter..... I tried turning it over and manually pumping the transfer pump again no fuel. I follow the lines from the tank all the way to the engine and I did not see any leaks or wet spots so I think they're good.
So process of elimination I should try to replace the lift pump? And cross my fingers?
www.shawntomskoolie.com
AZtom is offline   Reply With Quote
