Old 03-29-2016, 07:31 PM   #1
Chassis: TC2000 RE
Engine: Cummins 8.3; Allison 3060R
Rated Cap: 66 passenger
Cummins 8.3 low coolant light...
I am a few hundred miles from home and the low coolant light has started to flicker more and more frequently. Should I first just add in distilled water in the coolant tank, which has some fluid in it but is not very full. Any trick or do I just add in the distilled water (not sure if need to bleed or do something special?). Thanks, I don't want the family to get stranded on our fun trip...
engelstad is offline   Reply With Quote
Old 03-29-2016, 08:32 PM   #2
opus's Avatar
Chassis: All-American R/E
There should be a level line on the coolant tank. You should be fine putting water in it...provide its operational and has a hose connected to it going to the radiator.
Old 03-29-2016, 09:06 PM   #3
Chassis: TC2000 RE
Thanks! I don't see any level markings... should the tank be half full? Three quarters? Almost full? I will add water but am just not sure how full it should be. Thx!
Old 03-29-2016, 09:12 PM   #4
opus's Avatar
I'd go half. You could go more. If it expands too full it will just blow out the road tube.
Old 04-04-2016, 08:06 PM   #5
Chassis: TC2000 RE
Thanks, I put a bit more into the tank, such that it was probably 3/4 full (or more). I kept getting the intermittent "low coolant" light flashing on occasionally. Today, after the bus sat all day, I checked the electrical connection to the sensor, and it seemed good. I opened up the cap to the tank, and fluid gushed out, until I put the cap back on. At this point, I'm not sure if I still have bad sensor, or where the coolant goes when the engine is running a while, etc. ?? Any other ideas or suggestions?
Old 04-04-2016, 08:12 PM   #6
Chassis: IC CE
Engine: T444
you checked that the ground for the wiring is secured? do you have any pictures?
Azuleslight is offline   Reply With Quote
Old 04-04-2016, 08:17 PM   #7
Chassis: TC2000 RE
I am not sure how to verify the wiring ground. The 2 wires from the sensor disappear into the rest of a wiring harness. ?
Old 04-04-2016, 08:51 PM   #8
Chassis: IC CE
Engine: T444
I also just found a story, if this sounds familiars it might have the same cause. the person was going uphill when the light came on. Turned out that the coolant was 1 gallon low. If the coolant is above the max line (as it is needed to fill the other segments, supposedly), you should be ok. as for the grounding wire, it was a guess, others may have better info.
Old 04-04-2016, 09:02 PM   #9
Robin97396's Avatar
I think you got a big bubble of air in your cooling system, in the block.
Old 04-04-2016, 09:08 PM   #10
2kool4skool's Avatar
Bleed it. My FE has a small black plastic tube with a shut off on it. the inst. are under the rad. access cover. Warm engine, heater valves open, coolant should come of the valve.
Don, Mary and Spooky the cat.
