Old 01-19-2016, 08:27 AM   #1
Question Cummins DT666?
Hello, I was read upon busses for awhile and i think this is the engine i read was best. I want it with an automatic. No flat nose buses. What buses and years will i be looking at? Is the correct engine name?
I guess i might be thinking of the dt466. Fuel mileage?
Thanks
Old 01-19-2016, 11:05 AM   #2
Chassis: International 1753
Engine: 6.9 International
You're confused/misled.
DT466 is an engine built by Navistar/International. It's a member of the DT family which includes the more rarely found dt360,dt408, and dt530. The number after the DT indicates the engine displacement in cubic inches.
Cummins makes the B and C series engines(along with others, but these are found in busses). The B series is 5.9 L in displacement while the C is 8.3 L.
All three engines will work. The dt466 went to electronic control and HEUI injectors in the mid 90's. While Cummins went to electronics in the late 90's.
If I had to choose, I'd choose the dt466 because I feel it's a stouter, more serviceable engine. But I wouldn't shy away from any of them.
The most important factor in choosing which engine is how well it was serviced. Poor maintenance can ruin a good engine. So let the maintenance records and mileage be the deciding factor.
Old 01-19-2016, 11:31 AM   #3
Thanks. I just forgot what i have read here. I have connections to a bus company and might get a good deal.
Old 01-19-2016, 12:37 PM   #4
Moderator
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
If you go look at a bus with a DT666 you better take one of these with you.
I'm hungry!
You Gotta Let Me Fly
Old 01-19-2016, 12:39 PM   #5
dt466 It will be! Thanks
Old 01-19-2016, 12:43 PM   #6
And remember to only use Holy Water in the cooling system...otherwise, the Beast shall be unleashed.
