Old 12-18-2019, 11:04 AM   #1
Chassis: MVP/ER
Engine: Cat3126B 230hp
Rated Cap: 48
Cummins ISC engine
Looking fir my first Skoolie and found a 2005 blue bird AA with I think is a cummins ISC engibe. Is this a reliable and strong power plant??thank you fir any advice. Michael T.
Mat7783 is offline   Reply With Quote
Old 12-18-2019, 11:13 AM   #2
WIbluebird's Avatar
Engine: 8.3 Cummins ISC
Rated Cap: 75
I don't know much about the emission-era ISCs, they seem to have a fairly decent rep with the motorhome community. I do know that they have Common Rail injection as opposed to the older CAPS motors. The turbo is also a variable vane design so its more complex. It wouldn't have DEF, not sure if it would have an EGR cooler or not.
It's a wet sleeve design so it can be rebuilt inside the bus which cuts down on that cost a bit. Overall the 8.3 is one of if not the best motor you can get in a skoolie. Power wise there isn't really anything that can compete with it.
Old 12-18-2019, 12:10 PM   #3
Chassis: MVP/ER
Rated Cap: 48
Thank you for the valued imput
