Old 10-21-2018, 02:11 PM   #11
Bon Voyage's Avatar
Engine: Cummins ISC 260/660
Rated Cap: 81
Originally Posted by TJones View Post
I've been doing some research on the early ISC CAPS injection pumps. They will last longer if a low pressure fuel pump around 15 psi is placed at the fuel tank. This pushes fuel to the CAPS pump preventing it from pulling in air if there is a leak in the fuel line. It also pushes more fuel through the CAPS pump which improves cooling of the pump. I havn't had a chance to check my bus to see if it has an additional pump but it does have a fuel filter next to the fuel tank so I'm thinking it might.
Ted
Thatís interesting. Iíll have to read more about this too. Do you have any links Ted?
Bon Voyage is offline   Reply With Quote
Old 10-21-2018, 06:33 PM   #12
If it is a 5.9 that is nonsense. You can add nearly 50 hp with a screwdriver and no parts on a 4BT. More on a six. Check out the many Cummins forums (such as 4BTswaps.com). Between the smoke screw and timing you can do a surprising upgrade and often pick up a few mpg's in the process.
Old 10-21-2018, 06:34 PM   #13
See thread title.
Roll Your Own Build Thread
Old 10-21-2018, 09:59 PM   #14
TJones's Avatar
Chassis: CS RE
Engine: ISC 8.3 L 260 hp
Here is a thread discussimg the problem.
Repeating CAPS Failures - Need Help - iRV2 Forums
Ted
8.3, cummins, electronic, isc, mechanical
