Old 05-10-2017, 09:15 AM   #1
JojoBrisk's Avatar
Chassis: TC 2000
Engine: 5.9L Cummins
Diesel leak!!!
Hey Folks,
Been awhile since I've posted. I have a problem. I've found a leak from somewhere around my throttle area. It's just a drip, but I can't seem to pinpoint the origin. Does anyone have any ideas as to what it could be. I hope it's a simple fix, but I'm worried. I still get about 10 mpg, but leaking fuel is never a good thing. HELP!!!
1990 Bluebird TC2000
JojoBrisk is offline   Reply With Quote
Old 05-10-2017, 09:27 AM   #2
Year: 90
Chassis: international
We need a lot more detail than that. what engine? what pump? Post some pics.
Old 05-10-2017, 12:36 PM   #3
JojoBrisk's Avatar
Chassis: TC 2000
More info. Pictures to come.
Chassis: TC 2000
Old 05-11-2017, 04:49 PM   #4
Chassis: International 1753
Engine: 6.9 International
You're going to have to clean everything off and then pinpoint exactly where it's leaking. Could be an o-ring, could be a line, could be the pump. Can't really help with such few details.
Old 05-11-2017, 06:26 PM   #5
2kool4skool's Avatar
On our later Cummins we developed leaks on the engine mounted filter can.
The water drain valve was leaking, then all the o-rings leaked. (2 under the drain valve and the water in fuel sensor itself) Then under a block off plate for the optional heater. Replaced all the leakers, cheap and easy fix......Once I located the leaks that is.
Don, Mary and Spooky the cat.
