Old 03-05-2018, 07:18 PM   #1
Dodge truck diesel question?
Hey Everyone,
This is not bus related but I bet someone here has an answer.
I have moved to a small town in a cool climate. My only choices for my daily driver are my Dodge 3500 or a Ford E450. Both diesel.
Problem: I have the grill of my truck completely blocked to facilitate warming up. It still never gets up to operating temperature. My typical daily driving amounts to 4-5 miles. 10 if I am really busy. In the last 8 months I have made 2-3 trips long enough to get up to normal operating temperature.
I know that this is hard on a diesel. Short of moving I can't really solve the short trip problem.
Is there anything else I can do to mitigate this issue?
Thanks.
S.
Old 03-05-2018, 07:34 PM   #2
Chassis: Saf-T-Liner MVP ER
Hey Everyone,
Thanks.
S.
You can check that the thermostat is not stuck open.
10 miles isn't much distance to fully warm a big diesel engine though.
Steve Bracken
Build Thread
Old 03-05-2018, 07:42 PM   #3
Thanks Steve.
No the thermostat is not stuck open. it is a simple case of really short trips in freezing weather.
I manage a longer trip from time to time and it warms up normally.
It is the 2 mile trips in 30f weather that have me concerned.
Old 03-05-2018, 07:48 PM   #4
Block heater??
TrailLifeBill is offline   Reply With Quote
Old 03-05-2018, 07:54 PM   #5
Originally Posted by TrailLifeBill View Post
Block heater??
Thanks Bill,
Yes I have a block heater and use it. It does not warm enough to get the temperature gauge off of the peg.
I can tell the difference in how she starts if I forget to plug in.
Old 03-05-2018, 08:17 PM   #6
short trips wont warm it up... my red bus has a 444E.. (7.3 ford essentially).. even witha heavy bus attached it takes a bit to warm up.. if im a bad boy and dont warm it up when its in the teens or 20s.. (just start it and go).. it takes me 4-5 miles just to get up to 120 or where ill then turn on the heaters which make it warm very slowly after that..
if I let it sit and run for 10 minutes or so then drive it.. I am at 120 within a couple miles and in that same 5 miles I may be up to 145 or so (even with the heaters on)..
warm it up for a bit each morning and you;ll niotice a big difference in how warm the engine temp goes.
Old 03-06-2018, 09:03 AM   #7
Chassis: International 1753
Engine: 6.9 International
How long do you have the heater plugged in for? Unless it's 0 out with a head wind, the block heater should noticeably make the upper radiator hose warm. If not, your heater is slowly going bad. I've also seen cords go bad too so don't count them out either.
Old 03-06-2018, 09:04 AM   #8
And if after all that checks out, you're still too cold. You can get stick on oil pan heaters to plug in as well.
Old 03-06-2018, 09:20 AM   #9
My truck behaves similarly. Unfortunately a trip including the hardware store, supermarket and the pharmacy is a total trip of about 3 miles.
About every 6-8 weeks I drive to Walla Walla. My truck warms up fine after 5 minutes or less on the highway.
I think that my cooling system is operating properly. I just don't drive far enough to let it warm up fully.
I am looking for steps I may take to minimize or mitigate the ill effects of driving it that way.
Old 03-06-2018, 11:05 AM   #10
Engine: TE 444
Rated Cap: 12
Your best bet is to be a cheap beater car, the long trips you take help get the condensation out of the oil
