Old 03-26-2019, 05:33 PM   #1
MollyCMo's Avatar
Does 12-valve or 24-valve have anything to do with liters?
Iím looking for an 8.3 Cummins and I see some ads that say Cummins 12-valve or 24-valve with no mention of liters. Does number of valves have anything to do with liters?
Also whatís the difference between 12 and 24 valve, performance-wise?
MollyCMo is offline   Reply With Quote
Old 03-26-2019, 05:52 PM   #2
The 12v is mechanical the 24 has electronic injection. The 5.9 and 8.3 both come in either configuration.
Roll Your Own Build Thread
Old 03-26-2019, 05:52 PM   #3
Ronnie's Avatar
Engine: 345 international V-8
The 5.9 is often listed as 12 or 24 valve. 96 or 97 was the last year of the 12 valve in trucks.
Not so sure about the 8.3 as I have not heard it being anything but 12 valves.
Old 03-26-2019, 05:53 PM   #4
Ronnie's Avatar
Ok looks like I just heard of a 24 valve 8.3 ......
Old 03-27-2019, 08:10 AM   #5
WARGEAR's Avatar
Coachwork: AmTran/Wolfington
Engine: International DT466E 190HP variant
Rated Cap: 72 pax 29500 GVWR
The number 12 and 24 refer to the overall number of valves within the cylinder head. A 12 valve inline 6 cylinder engine will have 2 valves per cylinder and a 24 valve of the same configuration will have 4 valves per cylinder. It doesn’t have anything to do with displacement. More valves usually means an overall larger capacity for airflow which means better economy/power. But in this case either will be almost the same.
WARGEAR is offline   Reply With Quote
