06-09-2017, 01:31 PM
#21
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
Seriously, this is a piece of the conversion that I would be better off buying an off the shelf solution than trying to build it myself.
Is this off the shelf enough?
NEW 24V ALTERNATOR FITS CUMMINS ENGINE INDUSTRIAL B C K L SERIES 10459002 10459057
Be the first to review this item
Price: $192.95 & FREE Shipping
#22
Since I have a FE bus, even at the 5.9, I can't imagine getting another alternator up there where I already can't reach. I'd like the redundant power source idea and appreciate that it can be 24 volt. I was thinking of just a HO alternator.
Yes the Dodge forum is geared toward 5.9s, but we're only talking about pulleys and belts. It would be pretty simple to weld two single alternator brackets together. It takes a long time to build a bracket like that from scratch.
I'm not familiar with the RE buses engine compartment, but it sounds like you'd have adequate space to mount another alternator.
That's what's fun about building a bus. Figuring out how to do the things we're not supposed to be able to do.
Robin
Nobody's Business
06-09-2017, 01:36 PM
#23
I've got room for two of your quad alternator setups. Of course I could either drive the bus or drive the alternators at that point but there's lots of room on an RE.
^This^
06-09-2017, 02:07 PM
#24
I can't reach up to the front of my engine through the doghouse. Then again I don't have house batteries yet either. I like the separate alternator idea as a means of charging while traveling. I have no idea how to accomplish that in a FE bus though. Even installing a single HO alternator pretty much requires pulling the radiator.
I'm going to stick with just a generator for off grid for a year or two, and will likely have a few house batteries so I can run a TV on the mountain tops after dark.
Robin
Nobody's Business
06-09-2017, 02:13 PM
#25
Damn, didn't know it was that tight in an FE. Glad I don't have one. Sounds like dog nose is the way to go if you just gotta have an FE.
06-09-2017, 02:15 PM
#26
It is a thing of beauty!!
If it only came with a bracket to accomodate a dual alternator setup. Unfortunately it does not...
06-09-2017, 02:17 PM
#27
Room is not an issue on my RE. Plenty of space.
I can sit in the engine compartment next to the motor....
06-09-2017, 02:33 PM
#28
I don't think your '02 is set up the same as my '99. The routing of the turbo is different I believe. I don't know if that's because it is an '02 or because the bus I was looking at had the MD3060. If it is absolutely the same, I might could make you a bracket.
06-09-2017, 02:45 PM
#29
Here are a couple of engine compartment pics:
06-09-2017, 02:47 PM
#30
BrewerBob,
Any assistance would be appreciated.
I am not even sure where to put it and how to reroute the serpentine belt.
06-09-2017, 04:12 PM
#32
Man, that's clean enough to eat off of! It didn't come that way did it?
06-09-2017, 05:49 PM
#33
Chassis: thomas
Engine: 8.3 cummins
Rated Cap: 11 window
BrewerBob,
you can get another pully to drive the alt like they do for ac. less stress on the existing belt. you will need to have a mount fabbed up but wont be too pricey.
06-09-2017, 05:50 PM
#34
It's real. I can't imagine why, but it's real.
DUB cars with 5000 watt plus sound systems are often outfitted with lots of alternators and batteries
06-09-2017, 06:10 PM
#35
The string of four chrome alternators does look kind of pretty.
I like the redundancy theory of using two common inexpensive alternators that could easily be replaced while in a foreign country, like Kanada.
Robin
Nobody's Business
06-09-2017, 07:26 PM
#36
Coachwork: myself
Chassis: amtran
Engine: international dt466e allison md 3060
Rated Cap: 13 ton or so says the tit
Originally Posted by Tango
Dead Pirate --- does your 260 have an external rectifier? And how do you have it wired into your system?
Yes. It is switched. It can charge when the bank is just a little low. If it's below 10 volts Its too much of a drain and blows the circuit.
Sent from my LGLS676 using Tapatalk
06-09-2017, 07:29 PM
#37
Thanks...good to know --- I am hoping to be able to top off my house bank with the 250 I have installed. Just need to figure out how best to control it all.
06-09-2017, 07:37 PM
#38
Coachwork: myself
Chassis: amtran
Someone suggested that i run it through the solar charge controller. It can regulate the flow proper.
06-09-2017, 07:38 PM
#39
Coachwork: myself
Chassis: amtran
I run it through a 30 amp controller
06-09-2017, 08:03 PM
#40
Coachwork: myself
Chassis: amtran
Not sure if i said or not, but acontroller of some kind is needed. If the house bank is too low when you engage the alternator it will be a huge draw and ohms law and stuff.
