Old 03-26-2014, 11:42 PM   #1
Engine: 190hp 5.9 Cummins
Electric to mechanical lift pump 5.9 Cummins
In case anyone is doing a swap........
The fist gen dodge 5.9 Cummins from 89 to 93 used a electric lift pump in the fuel tank. This is the mechanical pump that replaces it, and prevents injection pump failure due to low fuel pressure. Most P pumped 5.9 Cummins that came stock in full size buses, already have this pump.
http://www.dieselbombers.com/5-9l-rotar ... -pump.html
First pic is the stock priming pump when using the in tank electric. When this one fails, it fills the crankcase full of diesel fuel.
Second and third pic are the manual replacement pump that eliminates the electric pump in tank. This mechanical pump pulls it's power from the camshaft lobe. When it fails, it simply starts leaking.
Parts needed.
Installed.
Old 04-05-2014, 09:23 PM   #2
Re: Electric to mechanical lift pump 5.9 Cummins
Interesting... I'll have to look for this on my bus on Monday when I pick it up. You said most P-pumped buses don't have to worry about this? Mine is a 92 with a p-pump.
Follow our conversion:
Two Birds - 1992 Bluebird TC2000
WVO Powered!
viewtopic.php?f=9&t=467346
www.LiveLoveTravelDream.com
White99z is offline   Reply With Quote
Old 04-05-2014, 10:19 PM   #3
Only the VE pumps had this issue. VE pump was never used factory in a bus that I know of. I just added this info for people repowering older buses with a 5.9 from another application.
Other applications would include, but not be limited to, Dodge Trucks, Generators, Industrial equipment, Farm equipment, ect.
Old 04-05-2014, 11:11 PM   #4
Gotcha! Thanks for the info.
WVO Powered!
Old 08-27-2015, 07:52 AM   #5
Chassis: Blue Bird TC2000
Engine: 5.9 Cummins 12 Valve VE pump
nat,
I have a 1990 blue bird that has a VE pump. like you said 89-93 dodges had them, but my TC2000 has one. i just got it so honestly don't know the full fuel system set up yet, but it is for sure a VE pump, i plan on putting a better fuel filter and pump system on it anyway, but just wanted to say there are buses out there with a VE pump. wasn't exactly what i wanted being as its not a p pump and doesn't have an intercooler, but it does have a heat exchanger....
Gotta be 10% smarter than the tool you're working with, or find someone else who is.
1992 TC2000 Cummins/Allison
Chiller is offline   Reply With Quote
Old 08-27-2015, 09:29 AM   #6
Intercooler is an easy add on. And according to the tech I'm working with at Diesel Specialists here in the Houston area...good for another 10-15% in both HP and MPG on virtually any diesel when sized and installed correctly.
Anybody converting mechanical fan to electric on their RE? boojiewoojie Mechanical and Drivetrains 23 08-02-2016 11:11 PM
Need a Cummins PT Pump frank-id Classifieds | Buy, Sell, Swap 2 01-29-2013 05:33 PM
Use of Cummins 5.9 manual priming pump? Elliot Naess Everything Else | General Skoolie Discussions 6 05-17-2007 10:16 AM
Looking for any information about Cummins PT Pump frank-id Everything Else | General Skoolie Discussions 1 04-11-2007 07:14 PM
blue bird cummins pump? The Wanderer Conversion General Discussions 9 02-28-2007 01:55 AM
