Old 12-22-2008, 01:08 PM   #1
Year: 94
Coachwork: b/b
Chassis: tc2000
Engine: 5.9
ENG turn up HELP
HA I NEED SOME HELP ,,,I HAVE A 94 BIRD WITH A 5.9 TA CUNNIS WITH A 545 TRANS AND A 478 REAR WITH ONLY 35000 MILES ,SHE RUNS AT 58 TO 60 MPH AT 2500 RPM .I WOULD LIKE TO GET MORE SPEED FROM HER AND DO ABOUT 65 SO WHAT CAN I DO TO??? THE PEOPLE AT THE CUMMINS HER SAY SHE CAN'T BE TURN UP ,WHat I GOT IS ALL I'LL get FROM HER AND SOME PEOPLE SAY.. SHE CAN BE TURN UP. SO I NEED TO KNOW FROM SOMEONE WHO KNOW THERE sh*t about these eng and help me,ALSO SHE 1100,22.5 TIRES
HELP HELP HELP THANKS
keith is offline   Reply With Quote
Old 12-22-2008, 07:19 PM   #2
the_experience03's Avatar
Re: ENG turn up HELP
You should be able to turn the governor up to achieve about 3000 RPM which should get you in your desired speed range. I think 3000 RPM should still be OK for your engine, but turning up the maximum speed must be done at your own risk. There are tradeoffs in everything. If you're spinning the engine 20% faster than before, for example, you will likely use 20% more fuel on top of the added wear and tear. That said, many on this site have had some pretty good success playing with the governors. I'm sure Jason will be around soon enough to let you know what you need to do on a Cummins (can't be much different than my 6.6 though).
Old 12-22-2008, 08:30 PM   #3
lapeer20m's Avatar
do you have a tach? I turned up phil's 5.9 and he can run a ridiculous 77 mph with 4.43 rear end. No clue about how many rpm's she's turning as the bus does not have a tach.
if your bus does 60 mph @ 2500 rpm....if we want to go 10% faster we can increase rpm's by 250
2750 rpm = 66 mph
3000 rpm = 72 mph
i'm not sure how fast that motor would spin, but i don't think i'd drive a sustained 3000 rpm's without researching what the top "safe" rpm is for the 5.9.
if you're turning up the rpm's, why not turn up the fuel at the same time?
there are 1 or 2 posts already on how to turn up a buses governor....i'll see if i can find the link. If you have bosch inline injector pump it's pretty easy...unless you have a flat front end bus, in which case it's pretty crappy trying to do even the simplest of tasks on the engine.
Old 12-22-2008, 10:02 PM   #4
Year: 94
Coachwork: b/b
Chassis: tc2000
Engine: 5.9
YES I HAVE A TACH AND ITS A FLAT NOSE F.E. MODEL THANKS
Old 12-22-2008, 10:09 PM   #5
Year: 94
Coachwork: b/b
Chassis: tc2000
Engine: 5.9
I DON'T KNOW WHAT KIND OF GROV SHE HAS BUT I HAVE THE SPEC ON THE BUS SHE A MODEL TCFE 3408 BODY F 108706 IF THAT HELPS ANYONE ????? THANKS KEITH
Old 12-23-2008, 08:31 AM   #6
open the engine doghouse and look down on the engine, the pump is at the left front of the engine, if it has fuel lines coming out of the top of the pump it is the inline pump, if the lines come out of the back of the pump it is a rotary pump, both are bosch units and very reliable.
Old 12-23-2008, 11:14 AM   #7
lapeer20m's Avatar
you may find this link helpful
http://www.skoolie.net/forum/viewtop...ngine&start=15
Old 12-26-2008, 12:06 AM   #8
Cant you just have the fuel pressure turned up? My dad has a 93 dodge pickup with a 5.9 and had the fuel pressure turned up and got 50 more horses. I would imagine you could do the same and get those results, of course you'ld have to bump up the govener or disable it alltogether.
EIBbus is offline   Reply With Quote
Old 12-26-2008, 06:02 PM   #9
lapeer20m's Avatar
The govenor and the amount of fuel injected into the engine are not really related, they are separate modifications.
You can "turn up" the fuel and increase your power while not affecting the rpm's at all.
alternatively, you can turn up your rpm's by 1,000 and not affect the hp....(except that hp is a measure of torque x rpm)
if you perform both mod's then you can have more power and faster engine speeds.
Old 11-17-2009, 02:53 PM   #10
frank-id's Avatar
Road speed
Making more engine power has just a small part in traveling at a faster road speed. With a high number rear gear ratio the gearing is very low. If ya want more speed, ya must change the rear gears. Trans with overdrive will help, larger wheels and tires will help, but the rear axle ratio will make ya go faster. I changed a bus to a 3:73 rear axle. It took about 3 miles to get up to 80 MPH. I'm thinking about some 3:55 for my Crown, but the engine needs more muscle. Frank
turn signal gasket somewhereinusa Conversion General Discussions 5 06-02-2012 01:43 AM
Help - international 3800 - will not turn over brent International | Navistar Drivetrain 5 04-15-2012 03:46 PM
Trying to turn off heater... timmygyu Short-Bus Conversion Projects 6 08-04-2011 06:01 PM
brake & turn lights chris white Conversion Tutorials and How-to's 13 06-22-2011 09:42 PM
How to turn a bus into a limo Please help me! wannabapartybus Titles, Insurance, Registration and Money Matters 7 02-25-2008 08:13 PM
