Old 10-26-2014, 08:49 PM   #31
opus's Avatar
Chassis: All-American R/E
Re: Extreme drop in horsepower
Well that was no fun. ;)
Old 10-26-2014, 09:27 PM   #32
Mark Antony Wray's Avatar
Chassis: All American FE
Engine: Cummins 8.3
..not for the Squirrel! I, on the other hand, was delighted to have evicted the power sucking vagabond.
Mark Antony Wray is offline   Reply With Quote
Old 11-03-2014, 08:07 AM   #33
Old 03-10-2015, 10:45 PM   #34
Engine: Cummins 8.3
FINALLY!!!...Found the problem with the power drop. It was simply a Turbo coupler that had cracks in the back side, and when the bus warmed up the silicon rubber got soft enough for the cracks to vent. My son discovered it with a spray bottle with dish soap and water...damned thing was foaming at the mouth like a mad dog! Now it's back to running like a bat out of hell!!...LOL! Man, this bus is like Kunta Kinte - It wants to RUN!! It's hard to keep it under 70mph....and smoooooth...emm, em, em!
Old 03-11-2015, 02:01 AM   #35
sojourner's Avatar
Engine: DT408
Same thing happened to me. Although my rubber coupler was cracked. When I picked up mine I had not driven one of these before. When I mashed on the accelerator I hear a big "whoosh" sound coming from the engine compartment (a FE). I though this was cooling fan noise and just thought the low horsepower was due to it being a DT408 and not the 466. Well, when checking fluids almost 3/4 of the trip home (total 1800 miles) I noticed some oil spray over the valve cover. Upon further inspection I found the turbo boot into the manifold was cracked. Popped into the next McDonalds for some coffee and free wifi and found an international dealer in Atlanta. Called them and they had the boot. $80.00 later and 15 minutes to change and OH MY!! What a change !!! Before I couldn't pull hills worth beans and loaded school buses were passing me like it was nothing for them. Now, I could accelerate up hills and this thing was actually "peppy". Strange thing is, even with the boos bleeding off I was still able to get 11.5/mpg. Probably because I listen to my turbo to tell where to run her. If the turbo is screaming or whistling where you ca n hear it, you're pushing it hard enough to adversely affect your mileage. Keep the exhaust clean (no black smoke) and the turbo quiet and they just sip fuel instead of gulping it.
I am an sojourner in the earth; hide not Your Commandments from me. Psalm 119:19
Here is the patience of the saints; here are the ones keeping the commandments of YAHWEH, and the faith of Yahshua. Rev. 14:12
sojourner is offline   Reply With Quote
Old 03-11-2015, 11:34 AM   #36
Engine: Cummins 8.3
I found a place on Ebay to buy Turbo Couplers. It's called DNA Motoring, and they only charged me $6.41 each and that INCLUDED freight and two lock bolt type straps that don't cut into the rubber!
Thank you for the tips....I appreciate you!!
Old 03-11-2015, 02:10 PM   #37
Coachwork: IC
Chassis: CE300
Rated Cap: 32
Very good to know, I'm going to replace mine soon, too.
Old 03-11-2015, 02:43 PM   #38
Engine: Cummins 8.3
We're all in this together aren't we!? Everything we can share with one another makes our community stronger!
Old 03-13-2015, 03:28 AM   #39
sojourner's Avatar
Engine: DT408
The one I was talking about that was cracked on mine is a factory formed rubber thing that connects the aftercooler tube to the intake manifold, not the silicone rubber tube that makes the torbo connections. One thing I think I will be doing in the future is build and aluminum replacement for the manifold junction and using the cheaper silicone rubber hoses to make the connections. Will be much cheaper to deal with in the future. If this happened once, while probably a long time away, it can happen again.
Old 03-13-2015, 11:06 AM   #40
Engine: Cummins 8.3
Ooooh, I see. My Son, who works at the Nissan Plant, told me some of the best things to carry in my emergency repair supply box is metal HVAC tape, metalized epoxy putty, 5 minute cure epoxy resin, 3 sizes of vise clamp pliers, and a small spool of 18 gauge unshielded solid wire. He said in many cases this stuff will help with smaller issues to allow you to limp home without super expensive road repairs. Makes sense to me.
In search of horsepower and big-time TORQUE John Chance Mechanical and Drivetrains 8 01-25-2012 07:30 PM
Extreme Noob with questions. Halitosis Conversion General Discussions 15 04-28-2009 04:40 PM
Price Drop SKIBUSENTRPNR2 Classifieds | Buy, Sell, Swap 0 12-04-2008 02:21 PM
Increasing Horsepower vikingalex Conversion Tutorials and How-to's 6 08-12-2007 02:43 PM
Speed/Horsepower Calculator trx Everything Else | General Skoolie Discussions 0 05-04-2005 08:08 AM
