Old 10-20-2015, 10:39 PM   #1
wunderhut's Avatar
Chassis: AARE 3903
Engine: Cummins 6CTA 8.3
Fan clutch wrong temperature range
My bus is running hot.
The fan doesn't kick on until 240ish* and it kicks back off at 215ish*! Gauges are accurate according to an IR thermometer...
Is the fan clutch bad or can something else cause this condition?
Engine is a mechanical 8.3 in an RE bus.
Definitely not driving this this anymore until I get this heat situation under control! Well, I'm not driving it anymore anyway until its converted over to RV...
wunderhut is offline   Reply With Quote
Old 10-20-2015, 10:50 PM   #2
Engine: 190hp 5.9 Cummins
That's not a clutch fan in a RE bus.
The fan is driven by a hydraulic motor driven by pressurized oil. The motor is triggered by a heat sensor in the coolant piping. Depending on the year it can be in a few different places.
Start tracing cooling lines, and rad hoses. Some of the sensors are in ports on the top of the engine head. There is also a port down under the top rad hose that is sometimes used.
Old 10-20-2015, 11:04 PM   #3
wunderhut's Avatar
Chassis: AARE 3903
Thanks nat.
I did know it wasn't actually the clutch type but I didn't know what else to call it.
What I did not know is how it was triggered. This will help me, thank you!
Old 08-07-2016, 06:22 PM   #4
Hey Nat. If the fan motor is leaking oil... Would this be a pressure issue, gasket issue and would this cause over heating?
Thanks
Ben
Ben Alth is offline   Reply With Quote
Old 08-07-2016, 06:25 PM   #5
Chassis: International S3800
is this bus using an air-controlled solenoid or is it a mechanical Viscous type clutch? a viscous clutch leaking will definitely be failing...
a viscous clutch running at the wrong temperature range can sometimes be adjusted..
Old 08-07-2016, 06:42 PM   #6
Thanks for responding Chris.
I'm going to say mechanical. It's a 1997 bluebird cummins 8.3. I needed to add about 1qt of oil every couple hundred miles to the cooling reservoir. Here is the catch. My temp gage is not working. I continued to replace oil for about 2500 miles. Drove it home to MD from AZ. It was strong and felt fine all the way. A faint beeping started up and I unplugged the temp sensor and let the fan run full speed. How would I adjust the fan to run at the correct temp. Of course, getting the temp gage working is first thing.
Ben
Old 08-07-2016, 06:55 PM   #7
I stopped and had some guy named "Big Rig" just look at it and he claimed the motor just needed a new gasket /seal. I figure the motor just needs replacement but I'm not sure that will remedy the overheating issue. Will the engine shut off automatically if it reaches a certain temp?
Old 08-07-2016, 10:23 PM   #8
Chassis: Genesis
Not usually. It will nicely destroy itself in different fun and exciting ways as it reaches different temperatures, however.
Timelord is offline   Reply With Quote
Old 08-08-2016, 07:48 AM   #9
good thing its a cummins... if it was a DT360/DT466 it wouldve been destroyed likely by that 240!! or at least the coolant wouldve all been in the oil....
im not familiar with the oil filled clutches that can have oil added.. im only familiar with the sealed ones that are simply temperature and hub driven...
I didnt realize it was an RE bus.. all my experience is on conventionals..
Old 08-08-2016, 02:03 PM   #10
JimW's Avatar
Chassis: Bluebird
Engine: 8.3 L Cummins
Rated Cap: 84 passenger
Having the same problem. Looking for a new clutch fan. This one is a Horton. Website says not being manufactured anymore. 1981 bluebird with 3.8 L Cummins. Any ideas?
JimW is offline   Reply With Quote
