Old 12-13-2017, 04:08 PM   #1
Doe69936's Avatar
Year: 2005
Chassis: School bus
Engine: Cummins
Fault code retrieval
Can anyone tell me how to retrieve the fault codes on a 99 fs65 5.9isb ?
Doe69936 is offline   Reply With Quote
Old 12-13-2017, 04:17 PM   #2
2kool4skool's Avatar
You can borrow my Scangauge D. Where are you?
Don, Mary and Spooky the cat.
Old 12-13-2017, 04:22 PM   #3
My 2002 Bluebird with an 8.3 Cummins has a switch next to the J1939 port that if held down while turning the ignition switch on will cause the codes to flash on an indicator on the dash. Kind of clumsy but functional if you don't have a scangauge.
Not sure if yours has the same but it may be worth investigating.
Old 12-13-2017, 04:39 PM   #4
Doe69936's Avatar
Year: 2005
Chassis: School bus
Engine: Cummins
Thanks for the offer it’s very generous unfortunately I’m in Arkansas and I think you are in Arizona still scan gauge d? I use a scan gauge 2on my power stroke maybe I can find one
Old 12-13-2017, 04:54 PM   #5
golfersmurf57's Avatar
Cummins quick check is a hand held but they're cosecktly. If it's obd2 ford truck software will do it. If it's Seitz connector you're talking OTC or Cummins quick check. My snap on red brick would do the powerstrokes.
That's the nice thing about the IHC's they can pull up codes from the dash.
Sent from my LGL64VL using Tapatalk
golfersmurf57 is offline   Reply With Quote
Old 12-13-2017, 06:03 PM   #6
Dash Fault Codes | blue-bird
Old 12-13-2017, 06:07 PM   #7
Doe69936's Avatar
Year: 2005
Chassis: School bus
Engine: Cummins
Ok thanks for the info
Old 12-13-2017, 06:09 PM   #8
Doe69936's Avatar
Year: 2005
Chassis: School bus
Engine: Cummins
Yeah I wish it was obd2 like my 7.3
Old 12-14-2017, 02:57 PM   #9
Doe69936's Avatar
Year: 2005
Chassis: School bus
Engine: Cummins
Ok so now I’m probably going to bite the bullet and get some new tools cause I don’t get any codes of the diagnostic button but when I drive it the check engine light comes on intermittently and it starts to lose a little rpms until it goes out again so I’m figuring I’ll need to see freeze frames and live data so anyone have any suggestions on hardware ? I’m not running a fleet here so the $1000 fix all kits are a ways out of budget but I am going to need something
Old 12-14-2017, 03:27 PM   #10
FWIW.
I had SES light often and it would clear itself. I can read my codes but you may be having the same, it sounds the same.
I unplugged the multi-pin plug that connects the engine to the chassis and slathered some dielectric grease on it and pugged and unplugged it several times. This prevented any codes for a long time. Recently had the problem again and I then replaced the crank position sensor and no more codes or power loss. The code was an RPM signal issue.
