Old 07-31-2019, 11:27 AM   #1
Doe69936's Avatar
Year: 2005
Chassis: School bus
Engine: Cummins
Front end alignment
2000 international 3800
So I replaced some worn the rod ends and to no surprise my passenger tire is worn down on the inside after a short while guess I Did not get the rod adjusted back in as well as I thought soooo doot dah dooo
Any one know how to alighn the toe in on a bus? the local international place won't be able to get at it for another week and they want $200 bucks for an alignment job which ain't bad I'm sure .still I think I can do it myself with a string and tape measure but never done it
Doe69936 is offline   Reply With Quote
Old 07-31-2019, 02:02 PM   #2
2kool4skool's Avatar
Put a piece of masking tape on the rear side of each front tire. Right on the tread in the center. Mark an X on each. Measure X to X. Drive one half tire revolution and remeasure. Ta-dahhh.
Don, Mary and Spooky the cat.
Old 07-31-2019, 03:11 PM   #3
HazMatt's Avatar
Chassis: IH 3800, 8 window
Ta-daa, indeed! [emoji106]
Old 07-31-2019, 03:42 PM   #4
But how do you know which side is out?
Old 07-31-2019, 04:20 PM   #5
Doe69936's Avatar
Year: 2005
Chassis: School bus
Engine: Cummins
Sounds like a fine way to measure so does any one know how much toe in shoukd be at the front compared to the back of the wheel ?
Old 07-31-2019, 05:18 PM   #6
Ronnie's Avatar
Engine: 345 international V-8
Should be able to look up alignment specs, but generally 1/8" toe in( 1/8 difference with front being less) on a full size chassis
Old 07-31-2019, 06:28 PM   #7
Sleddgracer's Avatar
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
start with your steering wheel locked in dead center, then adjust your wheels so they are both heading straight forward, then create your tow-in from there - if your steering wheel isn't dead center when your toe-in and alignment are done, your rig will continue to pull to one side or the other and continue to wear the tire(s)
Old 07-31-2019, 06:38 PM   #8
Doe69936's Avatar
Year: 2005
Chassis: School bus
Engine: Cummins
Thanks hadn't found anything on it yet
Old 07-31-2019, 06:38 PM   #9
Doe69936's Avatar
Year: 2005
Chassis: School bus
Engine: Cummins
Ok thank you
Old 08-02-2019, 06:40 PM   #10
Doe69936's Avatar
Year: 2005
Chassis: School bus
Engine: Cummins
Well she was about an in. Toed out so we'll see how good I did lining her up next trip
