Old 08-23-2019, 05:48 AM   #1
Engine: 8.3 Cummins MD 3060
Front hub oil?
My 2002 RE All American has a seep at one of the front hubs. I would like to get a new seal and replace oil but a quick search hasn’t produced and guidance. Can anybody point me in the right direction to get part numbers and oil specs?
2002 Bluebird All American RE 8.3 Cummins Allison MD3060. Located in Fulton MO.
Ernie's Autowerks is offline   Reply With Quote
Old 08-23-2019, 06:10 AM   #2
Johnny Mullet's Avatar
Engine: T444E 7.3L
Napa will have the hub seal. Replace the entire cap. They make a product called Lucas hub oil. That will fix you up.
Old 08-23-2019, 06:23 AM   #3
Doe69936's Avatar
Year: 2005
Chassis: School bus
Engine: Cummins
I prefer axle grease over hub oil
Doe69936 is offline   Reply With Quote
Old 08-23-2019, 09:23 AM   #4
Rivetboy's Avatar
Why is that? The hub was designed to use oil but you use grease?
Rivetboy is offline   Reply With Quote
Old 08-23-2019, 09:25 AM   #5
Engine: T444E 7.3L
Replacing with grease requires removing the hub and bearings to clean and change inner seal then pack with grease.
Old 08-23-2019, 10:13 AM   #6
Doe69936's Avatar
Year: 2005
Chassis: School bus
Engine: Cummins
Because grease doesn't leak
Old 08-23-2019, 10:35 AM   #7
Rivetboy's Avatar
OK, so that is the advantage? Wrestling that wheel off and pulling the drum off and finally the hub and packing the inner and outer bearings is a tremendous amount of work compared with changing a seal and running oil as designed. Those bus tires are big and heavy and the brake drum will pass as a boat anchor. Did not remove the hub when I did the front brakes. But, whatever floats your boat. As JM said up a few posts, NAPA has the seal
Old 08-23-2019, 11:18 AM   #8
Doe69936's Avatar
Year: 2005
Chassis: School bus
Engine: Cummins
OK, so that is the advantage? Wrestling that wheel off and pulling the drum off and finally the hub and packing the inner and outer bearings is a tremendous amount of work compared with changing a seal and running oil as designed. Those bus tires are big and heavy and the brake drum will pass as a boat anchor. Did not remove the hub when I did the front brakes. But, whatever floats your boat. As JM said up a few posts, NAPA has the seal[emoji3]
Well when I did mine I was doing bearings anyway and the leaking seal took out the brake pads too so I opted for the grease but yeah it was heavy
Old 08-24-2019, 07:39 AM   #9
Thanks y’all. Napa did indeed have the necessary cap and seal kit.
