Old 02-05-2013, 01:23 PM   #1
GreyEagle's Avatar
Re: Gaining Fuel Economy with the Cummins 5.9L
You didn't say from where you would be coming but???
If at all possible use I-80 ........ pretty much flat except for the climb out of Utah into Wyoming.......
or drop down to I-40....... I-70 is a heck of a climb but the scenery is much better than I-80 or I-40......
Best of luck either way..... have a safe trip.
GreyEagle
Roll - On...
GreyEagle is offline   Reply With Quote
Old 02-05-2013, 02:15 PM   #2
Moderator
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
My guess is you have an AT545 trans with a non locking TC. Change it to a MT643 and you'll probably pickup 1-2 mpg. I doubt the aftermarket intake breathes more than what is already on your bus.
I'm hungry!
You Gotta Let Me Fly
Old 02-05-2013, 08:19 PM   #3
opus's Avatar
Chassis: All-American R/E
More air in, more air out is the ticket. No gimmicks needed. Make it a leisurely trip and you'll do your best economy....but you probably knew that.
Old 02-05-2013, 08:45 PM   #4
Year: 94
Coachwork: b/b
Chassis: tc2000
Engine: 5.9
i pull off my muffer off and put a cold air box on ,5.9 at 545 and i get 13 mpg for a 72 passger bus. that big air filler on the bus that came with it.it reduce the air flow,so rerout the air intake and put a dodge air filer on it for a cummins.
keith is offline   Reply With Quote
Old 02-06-2013, 09:22 AM   #5
Keith
I am about to pull muffler off and move exhaust to the pass side to make room for some tanks etc.
How loud is it inside your bus?
I know the pickups here with 6 and 8 in exhaust and no mufflers are stupid loud; I plan to just cut off the 4 foot tip and then cut off muffler and reattatch the original size
I plan the air filter mod also...once the ground dries enuf to lay on it
Old 02-06-2013, 11:54 AM   #6
Year: 94
Coachwork: b/b
Chassis: tc2000
Engine: 5.9
I cut mine off at the back wheels area just in front of the axels and face it down and i don't even here it,i use all the pipe i toke off. MY bus just had a new muffer put on befor i bought it,,so if anyone needs a new one,,here it sits
also the cold air box is just behine the bumper alone the frame... makes that tubo sing
Old 02-06-2013, 03:28 PM   #7
Mine runs down pass frame,and then after the 4 foot muffler,it swoops in a big circle and passes over to the driverside (all that extra tubing just so kids didn't get smoked out when dropped off at the curb at school)
Old 02-06-2013, 04:23 PM   #8
Year: 94
Coachwork: b/b
Chassis: tc2000
Engine: 5.9
yep b/b did all there that way. fed law
Old 02-07-2013, 03:23 PM   #9
frank-id's Avatar
Cummins 5.9L
Removing a muffler on a 5.9 is a good thing as the turbo reduces any loud exhaust. Consider leaving about 5-6 ft of exhaust under bus and install a 90 degree fitting to direct exhaust to the side of bus.
TC means torque converter which is the coupling between engine and transmission. The Allison MT643 has a lock up converter. The AT 454 cannot be retrofitted with a lock up converter. Consider changing the rear axle gears for better economy. For a bit more power, consider water/alcohol, LPG, or nitrous gas. Check lots at google. Frank
Remember advice is worth what is paid. Not all advice is good. Use lots of research to prove every bit of information.
Old 02-27-2013, 12:36 PM   #10
frank-id's Avatar
In many cases, advice has a value equal to any payment. He said, she said, is bad information. Get a measuring device and go to a tire store and measure lots of tires with 22.5 and 24.5 wheel size. I think there is about just 1 inch difference. Rear gear change is the best for making better fuel economy. Frank
Old 02-27-2013, 12:38 PM   #11
opus's Avatar
I agree, gear change
Old 02-27-2013, 02:12 PM   #12
Originally Posted by Omerta
When looking to save on fuel economy these are the the first to cross my mind:
Subtle aero mods
Does this mean waxing the bus
A brick is a brick after all
Old 02-27-2013, 03:06 PM   #13
Year: 94
Coachwork: b/b
Chassis: tc2000
Engine: 5.9
tire on mine 12 x 22.5 from a 10x 22.5 pick up 3 miles an hour. biger the tire,lest the roution
Looking for a short bus. Fuel economy differences? OregonHempWorks Alternative Fuels | Electric, Propane, Wood & Biofuels 0 03-24-2014 01:15 AM
1985 GMC blue bird better fuel economy???? 1985bluebird GM | Chevrolet Drivetrain 9 07-22-2013 07:41 PM
Cummins 5.9 fuel plate help (and gauges) syke Conversion General Discussions 3 04-23-2013 10:59 PM
Question about fuel economy. Cellar Yeti Short-Bus Conversion Projects 4 12-18-2011 07:41 PM
Gearing - for power, speed, fuel economy? boyscout Conversion General Discussions 0 06-21-2006 05:32 PM
