Old 12-10-2008, 05:15 PM   #1
Train-train's Avatar
Got to go faster.
I have a local truck shop that I have visited to get some ideas from. My bus has a 5.9 Cummins with 4.63 in the rear. They say they can find a better rear for me for six hundred including labor. They were thinking a 4.10. Wound this work for what I want to do?
Train-train is offline   Reply With Quote
Old 12-10-2008, 06:45 PM   #2
Elliot Naess's Avatar
Engine: 5,9 Cummins
Re: Got to go faster.
You can make calculations in a jiffy with this:
http://www.idavette.net/tech/ratioc.htm
Simply go to that site and punch in any three of the four numbers, then hit "compute" for the fourth. Magic!
Elliot
Old 12-10-2008, 06:59 PM   #3
phillbus914's Avatar
try one of these calculators and see how much that'll affect your RPM's http://www.corral.net/tech/gearcalc.html
4.63 to 4.10 doesn't seem much difference
My Old Bus :(
Old 12-10-2008, 09:01 PM   #4
the_experience03's Avatar
In theory he should be able to hit darn near 80 mph at 2600 RPM assuming he has 10.00R20/11R22.5 tires. That's also not including any tranny slippage. I think 70-75 mph would be doable. That might be worth the $600. The $600 is parts and labor? If so you're getting a deal. I've done some rear ends for smaller stuff and by the time you get a master bearing kit, shims, and the actual gears you can be in it for $250. If you add in the $100-$200 labor (going rate on rear ends) and you aren't but a few bucks short of what they quoted you for a much larger, heavier rear end.
Old 12-11-2008, 10:12 AM   #5
CAMO-MONSTER's Avatar
Year: 1974
Coachwork: CARPENTER
Chassis: GMC-6000
Engine: 454 CHEVY
I WANT TO SWOP THE THERD MEMBER IN MY GM T170 TWO SPEED REAR END
MOTOR CHEVY 454
TRANS NP465 FOUR SPEED
TIRES 9.00 X 20
REAR END GEARS ???????
DO'S ENONE KNOW WERE I CAN FIND A THERD MENBER THAT WILL LET ME
DO UP TO 75 - 85 mph ?
CAMO-MONSTER
hd d44 4.56, eaton ff 4.56
CAMO-MONSTER is offline   Reply With Quote
Old 12-11-2008, 01:23 PM   #6
Year: 94
Coachwork: b/b
Chassis: tc2000
Engine: 5.9
ok i got a 5.9 cunni with a at 545 with a478 rear and i want to run about 65to 70 and they say i can't turn it up ,,it runs right about 58 to 60 on the hiway ,now this is a 94 bb 5.9 12 vale pump i feel the need for some speed,,,, help or should i sell it,,, now this was told to me by 4 diff cunnins men ,you can't turn it up... HELPPPPPPPPPPPPPPPPPPPP
keith is offline   Reply With Quote
Old 12-11-2008, 05:33 PM   #7
Steve's Avatar
And assuming it has the power to overcome drag and grade!
Old 12-11-2008, 11:25 PM   #8
I have the same engine in my bus, with a 4.33 rear end and I can hit 77mph. Not sure what my RPM's are though since I have no tach. I'll tell ya though, I usually cruise 60-65 because fuel economy gets real bad above that.
My Old Bus :(
Old 12-12-2008, 12:19 AM   #9
Joe Monstermaker's Avatar
Just make sure you're never going to need low gear to get moving on a steep grade with a heavy load... ever. Busses have low gears for a reason!
It sucks that the transmission doesn't have enough gears, with a wide enough ratio spread.
Joe Monstermaker is offline   Reply With Quote
Old 12-12-2008, 02:56 AM   #10
Year: 1974
Chassis: GMC-6000
Engine: 454 CHEVY
THAT IS WHAT MITE BE GOOD ABOUT MY REAR END WHICH
IS A TWO SPEED.
BUT I STILL WOULD LIKE TO TRY AND FINED HIGHER GEARS
FOR MY DIFF.
CAMO-MONSTER
Can a transit bus be made to go faster for highway speeds? lornaschinske Mechanical and Drivetrains 5 04-16-2012 10:29 AM
