Old 06-27-2017, 04:06 PM   #1
Dead pirate's Avatar
Coachwork: myself
Chassis: amtran
Engine: international dt466e allison md 3060
Rated Cap: 13 ton or so says the tit
Grey oil in my 5.9
Looks like i have to fix a crack or gasket? Any hints on getting the head out or diagnosis tricks?
Sent from my LGLS676 using Tapatalk
Dead pirate is offline   Reply With Quote
Old 06-27-2017, 04:08 PM   #2
Coachwork: myself
Chassis: amtran
Could this be a seal on the injector pump?
Old 06-27-2017, 05:25 PM   #3
Njsurf73's Avatar
Chassis: Bluebird
Engine: 5.9 Cummins 24v
Rated Cap: 72 pax
What pump?
Old 06-27-2017, 06:42 PM   #4
Pressure test the cooling system first, there are several places for water to get in. Do you have an oil cooler I.e. Water to oil?
Don't drive it!
I'm an ex ag mechanic so my knowledge is borderline (dangerous) on busses.
Steven UK is offline   Reply With Quote
Old 06-27-2017, 06:47 PM   #5
Coachwork: myself
Chassis: amtran
Originally Posted by Njsurf73 View Post
What pump?
I was thinking diesel was getting by the injectors, but after letting it settle i can see it's water. The diaphragm could get a hole? Was my thinking. Is there no pump? I know the injectors are mechanical.
Old 06-27-2017, 07:36 PM   #6
Njsurf73's Avatar
Chassis: Bluebird
Rated Cap: 72 pax
It could be a few things.
Some air pumps have coolant lines.
Turbo can leak coolant (not sure if it can leak into the oil)
Head gasket
Cracked block.
Check your coolant to see if there is oil in it.
That's about the best I can do.
Old 06-27-2017, 07:46 PM   #7
Coachwork: myself
Chassis: amtran
Thanks. Im gonna pull the head. Hopefully just a gasket. It runs great. And it's not that much water.
