Old 07-20-2015, 08:09 AM   #21
Dammit's Avatar
Chassis: TC2000 RE
Engine: Cummins 8.3
Rated Cap: 78 passenger
Looking at my own rat's nest and corroded undercarriage, my money is on wiring. We'll see...
Dammit is offline   Reply With Quote
Old 07-20-2015, 11:19 AM   #22
Bus dad's Avatar
Year: 98
Chassis: TC 2000 RE
Engine: 8.3 cummins mechanical
Praise God! Thank-you SO MUCH Smartfly! I moved the plunger up and down with a wrench first manually, checked to make sure I had voltage, and then turned the key and bus started in two cranks!
Bus dad is offline   Reply With Quote
Old 07-20-2015, 12:06 PM   #23
Ok, remember the first rul- Don't Panic!!
Is the fuel shutoff working properly? Diesels usually stop because there isn't fuel.
also-tap on the tank and make sure it has fuel.
Gauges are notorious for being utterly horrible.
check if you have any emergency hatches/latches that aren't secured.
oh-I'd check all battery connections, all chassis grounds, all engine grounds and make sure they are clean & tight
I win on guess one!
Glad you're ready to roll!
Old 07-20-2015, 02:07 PM   #24
Good info guys!
Old 07-20-2015, 02:29 PM   #25
Bus dad's Avatar
Year: 98
Chassis: TC 2000 RE
Thanks again to all
David
Bus dad of 3 and husband of 1 ( wife that is )
Old 07-20-2015, 02:51 PM   #26
Moderator
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
I win on guess one!
Nope, yours don't count. You didn't give detailed step by step instructions.
I'm hungry!
You Gotta Let Me Fly
Old 07-20-2015, 02:59 PM   #27
Bus dad's Avatar
Year: 98
Chassis: TC 2000 RE
But Smartfly did- It really helped having step by step- Im not a wrench, but if someone give me instructions I can follow ( maybe (lol)
David
Old 07-20-2015, 03:02 PM   #28
Better get handy with a wrench owning one of them there Cummins!
lol
Old 07-20-2015, 03:13 PM   #29
Moderator
crazycal's Avatar
lol
No kidding. Hand holding only goes so far. Just so you know, you won't always get step by step instructions. You should learn the basics about your bus. The internet won't always be available. There will be times when you are somewhere and your bus won't start. It could be something as simple as a wire or relay. If you drove it there and parked it and now it doesn't start, you should have an idea where to start checking.
I'm hungry!
Old 08-03-2015, 02:37 PM   #30
Did you get your electrical troubles resolved that operate your fuel shut off solenoid?
I had a simular trouble, here is the thread where; with help from other people on this forum I found the relay that was the trouble.
http://www.skoolie.net/forums/f33/st...die-11191.html
c_hasbeen is offline   Reply With Quote
Old 08-03-2015, 03:27 PM   #31
Bus dad's Avatar
Year: 98
Chassis: TC 2000 RE
no electrical the plunger needed prompting works fine thanks did you get my vm
David
