07-26-2017, 01:38 PM
#21
Coachwork: myself
Chassis: amtran
Engine: international dt466e allison md 3060
Rated Cap: 13 ton or so says the tit
I love skoolie.net.
Sent from my LGLS676 using Tapatalk
07-26-2017, 03:17 PM
#22
Originally Posted by Dead pirate
I love skoolie.net.
I love the folks on here, always nice folks willing to help others.
Water pump isn't too hard a job. you gonna do it yourself?
07-26-2017, 03:18 PM
#23
Coachwork: myself
Chassis: amtran
No. The radiator has to come out
07-26-2017, 03:45 PM
#24
Not too hard. Is it a FE, CE, or RE?
#25
Coachwork: myself
Chassis: amtran
Mid. So ce?
07-26-2017, 03:47 PM
#26
Where is the engine on your bus? In front of the coachwork, or buried under the cab like a van?
07-26-2017, 04:13 PM
#27
Coachwork: myself
Chassis: amtran
Its a flat nose.
07-26-2017, 04:21 PM
#28
sure sounds like a turbo leak.. can you get any of that sound by brake torque the bus when its stopped? or is it only when you are rolling?
could be a rear end going out if its a WAIL From that area and you cant even get anything close to it when doing a brake stand spool up..
I always think of turbo leaks as a whistle or a 'ssssssshhhh!!' type sound...
07-27-2017, 01:06 PM
#29
Coachwork: myself
Chassis: amtran
On the road again!
07-27-2017, 03:31 PM
#30
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
So what was the problem?
07-27-2017, 04:46 PM
#31
Coachwork: myself
Chassis: amtran
it's over heating still. New thermostat. Me water pump. The temp gauge swings up to 240 and back down to 200 real fast. Eventually it stays up and it needs water. I can't find a leak any where.
07-27-2017, 04:58 PM
#32
Chassis: International 1753
Engine: 6.9 International
Is the wail gone? Did you purge all the air out of the system when you filled with coolant?
07-27-2017, 06:20 PM
#33
Chassis: IH
Make sure coolant isn't getting into the oil.
07-28-2017, 09:18 AM
#34
Coachwork: myself
Chassis: amtran
The wail is gone. It was bad boot on the turbo. Purge the air?
07-28-2017, 09:20 AM
#35
Coachwork: myself
Chassis: amtran
I think it is. I'm gonna change the oil and start over.
07-28-2017, 09:21 AM
#36
When you changed the thermostat/water pump. Did you purge all the are out of the system?
07-28-2017, 09:22 AM
#37
Coachwork: myself
Chassis: amtran
It was done at a shop, so I'm guessing yes. The mechanic was good. He tightened up other issues too
