Old 07-25-2017, 05:04 PM   #1
Dead pirate's Avatar
Coachwork: myself
Chassis: amtran
Engine: international dt466e allison md 3060
Rated Cap: 13 ton or so says the tit
High pitched wail.
When we are rolling it screams when i accelerate. Can't get rolling as fast as it usually does. Runs and sounds great otherwise.
Sent from my LGLS676 using Tapatalk
Dead pirate is offline   Reply With Quote
Old 07-25-2017, 05:18 PM   #2
brokedown's Avatar
Check your bus to make sure my ex wife isn't hiding in it!
Old 07-25-2017, 05:42 PM   #3
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
Get the cat out from under the hood!
Old 07-25-2017, 05:43 PM   #4
Coachwork: myself
Chassis: amtran
Can i rebuild the inner cooler on the turbo?
Old 07-25-2017, 05:45 PM   #5
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
The intercooler is nothing more than a radiator for the compressed air.
Old 07-25-2017, 05:46 PM   #6
Coachwork: myself
Chassis: amtran
Can i fix it myself
Old 07-25-2017, 07:03 PM   #7
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
No moving parts in an intercooler. It's just a RADIATOR. The wailing comes from a moving part. Get a LONG handled screwdriver, hold the tip to moving parts and hold the other end to your head next to your ear. Bone conduction will do the rest. It acts as a stethoscope.
Old 07-25-2017, 08:21 PM   #8
Coachwork: myself
Chassis: amtran
Thanks.
Old 07-26-2017, 07:16 AM   #9
Njsurf73's Avatar
Chassis: Bluebird
Engine: 5.9 Cummins 24v
Rated Cap: 72 pax
Of it is poorly accelerating, check any rubber connections post turbo. The wailing may be a hole it rip in a rubber boot... Turbo whine and air escaping?
Otherwise I would concentrate on your turbo 1st.
Old 07-26-2017, 08:18 AM   #10
Chassis: Blue Bird
Engine: ISC 8.3
Ditto that. Check for an air leak after the turbo. Torn boot, loose connection, etc. Noise can come from moving air.
