07-25-2017, 05:04 PM
Coachwork: myself
Chassis: amtran
Engine: international dt466e allison md 3060
Rated Cap: 13 ton or so says the tit
High pitched wail.
When we are rolling it screams when i accelerate. Can't get rolling as fast as it usually does. Runs and sounds great otherwise.
Sent from my LGLS676 using Tapatalk
07-25-2017, 05:18 PM
Check your bus to make sure my ex wife isn't hiding in it!
07-25-2017, 05:42 PM
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
Get the cat out from under the hood!
07-25-2017, 05:43 PM
Coachwork: myself
Chassis: amtran
Can i rebuild the inner cooler on the turbo?
07-25-2017, 05:45 PM
Chassis: HDX
Engine: Cat C7
The intercooler is nothing more than a radiator for the compressed air.
07-25-2017, 05:46 PM
Coachwork: myself
Chassis: amtran
Can i fix it myself
07-25-2017, 07:03 PM
Chassis: HDX
Engine: Cat C7
No moving parts in an intercooler. It's just a RADIATOR. The wailing comes from a moving part. Get a LONG handled screwdriver, hold the tip to moving parts and hold the other end to your head next to your ear. Bone conduction will do the rest. It acts as a stethoscope.
07-25-2017, 08:21 PM
Coachwork: myself
Chassis: amtran
Thanks.
07-26-2017, 07:16 AM
Chassis: Bluebird
Engine: 5.9 Cummins 24v
Rated Cap: 72 pax
Of it is poorly accelerating, check any rubber connections post turbo. The wailing may be a hole it rip in a rubber boot... Turbo whine and air escaping?
Otherwise I would concentrate on your turbo 1st.
07-26-2017, 08:18 AM
Chassis: Blue Bird
Engine: ISC 8.3
Ditto that. Check for an air leak after the turbo. Torn boot, loose connection, etc. Noise can come from moving air.
07-26-2017, 10:01 AM
Coachwork: myself
Chassis: amtran
I can't find it. Maybe the turbo is bad. It has been over heating now also.
07-26-2017, 10:05 AM
Coachwork: myself
Chassis: amtran
And I'm broke down in Indianapolis.
07-26-2017, 10:53 AM
Does it make the noise when it's stopped? What about revved up when stopped? Where does it sound like it's coming from, towards the front, rear, left right? Need a lot more info on whats going on.
07-26-2017, 11:07 AM
Coachwork: myself
Chassis: amtran
No. Not when we are stopped and revved. Can't really tell where it's coming from.
07-26-2017, 11:08 AM
Coachwork: myself
Chassis: amtran
I dont think its the boot
07-26-2017, 11:09 AM
Coachwork: myself
Chassis: amtran
When it screams the engine gets hot.
07-26-2017, 11:10 AM
Chassis: Bluebird
Rated Cap: 72 pax
Could be the water pump.
07-26-2017, 11:11 AM
I'm thinking so too. Water pump is shot and the wail is either the bearings or the belt. Pull the belt off and see how the pump turns.
07-26-2017, 11:50 AM
Coachwork: myself
Chassis: amtran
Damn. The water pump. It only screams when the turbo should be running, but I'll check the water pump. I'm out on the highway.
07-26-2017, 01:37 PM
Coachwork: myself
Chassis: amtran
Its the water pump. Thank you all for your help.
