05-05-2017, 08:19 AM
Chassis: Ford B600
Rated Cap: 20 person
I can't drive 55....
Well actually yes I can but that is all I get out of my bus. I know this is normal for safety reasons for the children.
Now that my skoolie is no longer a bus how can I get past this limitation? I don't want to do 80 but I would like to at least keep up with traffic and not be a traveling road block.
Any suggestions?
"Living Our Own Story"
The Bowser Journal
Watch our adventures by subscribing...
Youtube - bit.ly/TheBowserJournal
05-05-2017, 08:27 AM
do you know what RPM you are at when you hit max speed, and then what rear gears you have?
05-05-2017, 08:33 AM
reset your expectations of a bus and learn to enjoy the ride. otherwise, break out the wallet. rear gear will get you most bang for the buck. i moved the fuel plate on my cummins and got a few (3 or 4) more mph. new bigger tires will kick you up a bit too. to make a major difference it cost some $$$$$.
05-05-2017, 09:11 AM
Chassis: Ford B600
I do enjoy the ride, just get concerned about everyone passing me like i am a road block. How do I determine my gear ratio? I know on my old hot rods you could jack up one side and mark the drive shaft and wheel and count the revolutions but this is just a tad bit heavier than my Chevelle.
The Bowser Journal
05-13-2017, 10:12 PM
I've got the same engine in a Blue Bird. Does around 65. What transmission? Air or juice brakes?
05-13-2017, 11:53 PM
i think i recall someone saying to tape a string to your driveshaft, roll the truck one tire revolution and count the wraps of string on the drive shaft.
05-14-2017, 12:37 AM
Year: 1975
Chassis: Gillig
That method will work for your bus.
As has been mentioned changing the rear end gears is the easiest way to get more speed.
05-14-2017, 07:42 AM
The other possibilities are an axle swap for one that's a 2 speed. Picked up a Ford cab and chassis recently for $400. I was more interested in the tires, hood, etc. If you go that route look for a diesel chassis. A gasser will rev higher meaning a bigger numerically rear end which you do not want. I know of a 70's era International that had a 5.9 swapped for the original gasoline engine. The ring and pinion were changed out. It will easily do 75mph loaded. If you have a standard instead of an automatic an overdrive transmission is another option from a donor chassis.
05-14-2017, 07:55 AM
Any suggestions?
I know how you feel about being a road block, but as long as I can keep the speed limit everyone else can go around, like turf said, enjoy the ride
05-14-2017, 09:42 AM
Chassis: Ford B600
545 tranny and air brakes
The Bowser Journal
05-14-2017, 10:04 AM
Don, Mary and Spooky the cat.
05-15-2017, 04:16 PM
Chassis: Ford B600
Now that is funny! How did you ever find that video?
The Bowser Journal
05-15-2017, 05:35 PM
I'm retired, have nothing else to do
05-16-2017, 08:13 AM
Chassis: Ford B600
Well maybe once we get our skoolie done and hit the road full time our paths will cross and we can hang out.
The Bowser Journal
05-16-2017, 08:16 AM
Don and Mary are really cool, I'd like to meet them as well.
05-16-2017, 08:58 AM
Coachwork: Chevrolet
Chassis: B-60 Short Bus
Engine: 6.7 liter Chevrolet
Rated Cap: 22,000 GVW
We've just gotten used to the 50-55 mph speeds. If you are traveling off interstates, no one really gets too chapped about having to pass you. We call it a "parade" and sometimes will count the number of cars behind us when we finally pull off and let them go by. It helps to have a sense of humor about it!
One memorable day, on a long downhill run in Hungary, we topped out at 57 mph! It remains the bus speed record. One thing I regret is that we weren't able to make it to the Nurburgring in Germany on one of their public days just so we could have said we'd driven a school bus around the track.
