Old 11-09-2019, 04:04 PM   #1
Coachwork: El Dorado National
Chassis: Escort RE
Engine: Cummins C8.3
Rated Cap: Not sure (32 foot model)
I can't drive past 55! Governor/limiter question
I'm crafty and mechanically inclined, but I have never had the time or place to take apart an engine and learn its secrets, do what may be old hat to many of you is still a mystery to me. I am especially dumbfounded by diesels, and now we have one.
It's a c8.3 in a 97 ElDorado National Escort RE, don't know what transmission yet as I haven't looked for the nameplate. Drove it with the pedal to the metal for an hour straight with no issues, but it's governed out limited to 55mph. It holds steady at 2250rpm, and there's no electrical on this engine, so I'm pretty sure it's a mechanical limiting device that may be removable.
Our mechanics have not looked at it yet (no plates, and their shop is by the Tacoma Police fleet station), but when I mentioned the speed limiting and possibly adjusting or removing it, they got that look that mechanics get when you mention something that will cause certain death. They both spoke of vehicles unexpectedly taking off after the limiters were removed, one being in a shop when it happened.
I trust our mechanics, they're family, but I can't wrap my head around the scenario. Is this possible? Is there a way to prevent it? I just want to be able to hit 60mph!
The previous owners told me all kinds of things that they had done to the bus, like an in-frame rebuild and replacing the differential so that it can go up to 70mph (the first exposed lie, though I bet it could without the limiting).
MilesOriginal is offline   Reply With Quote
Old 11-09-2019, 04:13 PM   #2
Need lots mor einfo, what rear gear does it have, what transmission. Usually the older motors were governed with a mechanical spring set up that senses load, the more load you apply the more it slows the engine.
Here's a previous thread on the subject.
http://www.skoolie.net/forums/f36/8-...n-15247-3.html
Old 11-09-2019, 04:46 PM   #3
Chassis: Escort RE
Thanks for the link, I couldn't get any good results from searching the forums.
I'll have to get that info on the transmission, and I have no idea how to figure out the rear gear info.
Old 11-09-2019, 05:06 PM   #4
Get a VIN#, the dealer site can tell exactly what's in it.
Old 11-09-2019, 09:49 PM   #5
Coachwork: In the market
I think that brand/model was much more designed as a city transit or shuttle bus, not a highway cruiser. Therefore it may not be geared for much more than 55 even if you defeat the limiter. Especially if you're already turning 2250rpms at 55mph, unless there's some hidden top gear I think that may be all she's got. A prior owner says they regeared? Not sure what that got them, maybe now we know why they unloaded it.
Sehnsucht is offline   Reply With Quote
Old 11-10-2019, 02:38 PM   #6
Chassis: Escort RE
The prior owners had it for 11 years and used it as a church shuttle for their seniors. The driver of the bus worked for the city transit, and he unloaded on me for about an hour, all of the things he replaced and rebuilt, as well as what he didn't do and why. The problem with all of that is that he said he replaced the differential and that it could now do 65-70 on the freeway. One lie makes me wonder how much of the rest of what he said he did was actually done. But, doing 55 at 2250rpm, I'm sure it could do 65-70 (until it pops).
Does it seem unreasonable to be expecting 60mph at 2300rpm? Wouldn't that be in the sweet spot for rpms, or is it different with a diesel?
Old 11-10-2019, 02:56 PM   #7
I would suggest looking closer to the engine. The 8.3 went electronic in '96.
It could be that Eldorado bought a '96 chassis and finished it in '97 but there is a good chance that you have an electronic engine and the governor is set in programming.
The 8.3's Max rpm varies by application but is around 2500-2600rpm.
Old 11-10-2019, 03:44 PM   #8
Chassis: Escort RE
No electronics on this one.
I had no idea how different the rpms are from a car, that's an eye opener.
So, if I'm maxed out at 55mph - 50mph on I-5 inclines - am I going to be dragging along at 40-45 with a tow vehicle?
Old 11-10-2019, 03:55 PM   #9
Probably not.
I have an 8.3 in my full size Bluebird. From the Eldorado's that I have looked at, I suspect that yours is lighter.
I packed a houseful of stuff in the back of the bus when I moved to the East side. I mean packed. I pulled Snoqualmie pass at 55. Not because of a lack of power. It was in the high 90's outside and I was not in a hurry. On the steep bits the coolant temps started climbing a bit so I backed out of the throttle a bit.
Last time I was in Tacoma I was attending a training class hosted by TPD. Nice folks.
55mph, faster, governor, iimiter, speed
