Old 12-08-2017, 04:00 PM   #1
Coachwork: Blue-Bird
Engine: 5.9
Iinjector lines
Looks like I need #5 and #6 injector lines form my Cummins 5.9 6B. Any one have a good source. Has anybody used flexible injector hoes before.
Thank You
David Moose
Moose is offline   Reply With Quote
Old 12-08-2017, 06:34 PM   #2
Johnny Mullet's Avatar
Engine: T444E 7.3L
I always got mine from a local parts store like Napa and if there was an issue or defect, I can return it hassle free.
Old 12-08-2017, 08:11 PM   #3
Rivetboy's Avatar
Hi David,
Are you registered on the Cummins Quik serv site?
All you need is the serial number of your engine to sign up and bam, manuals, part numbers, exploded diagrams and it is all free.
Then , armed with the part number you need you can start seaerching. Napa, ebay, etc.
Good luck
Joe
Rivetboy is offline   Reply With Quote
Old 12-08-2017, 11:25 PM   #4
Year: 90
Chassis: international
No, you absolutely cannot use flexible fuel hose for injector lines. There is up to 2000 psi fuel pressure in them. get the right ones for your engine from a wrecking yard or dealer.
Old 12-09-2017, 12:05 AM   #5
Chassis: Saf-T-Liner MVP ER
True, but it's available ar Autozone and O'Reilys.
It's marked for use with injector systems and the counter staff should ask you if you want high-pressure or regular hose.
That said ... if the manufacturer used steel lines, that's what they should be replaced with.
Steve Bracken
Build Thread
Old 12-09-2017, 05:22 AM   #6
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
Emergency Diesel Fuel Injection Injector Line
Name:	Screen Shot 2017-12-09 at 5.20.24 AM.png
Old 12-09-2017, 09:56 AM   #7
golfersmurf57's Avatar
Cummins will have the lines. Flexible hoses will flex and affect injection timing
Sent from my LGL64VL using Tapatalk
golfersmurf57 is offline   Reply With Quote
Old 12-09-2017, 11:27 AM   #8
Rivetboy's Avatar
Cummins quik serve
Here you go.
