Old 06-18-2018, 10:10 PM   #1
Dapplecreek's Avatar
Rated Cap: 44 or 66? 11 rows
Is a Cummins filter a Cummins filter?
I have a 2002 Freightliner/Thomas with a Cummins 5.9 engine.
Can I just trot down to the auto parts store and ask for a 2002 Cummins oil filter? (as in "Dodge"?)
And is there a brand I want or a brand I don't want?
Thanks, folks!
Dapplecreek is offline   Reply With Quote
Old 06-19-2018, 08:07 AM   #2
Chassis: International 1753
Engine: 6.9 International
No, I believe the threads for the filter are different IIRC. Dodge is smaller and uses like an inch diameter thread while your commercial cummins will use larger 1 and 1/8" threads.
Get a good filter. Wix, Baldwin, Hastings, etc.
I avoid Fram because of their issues a few years ago.
Old 06-19-2018, 08:08 AM   #3
I can go in the shop and get you numbers if you'd like.
Old 06-19-2018, 08:20 AM   #4
Booyah - I would greatly appreciate that! Thanks!
I don't have the engine number handy, and I'm doubting the VIN would help... but it's a 5.9 Cummins in a 2002 Freightliner drivetrain/Thomas body bus (mfg 11/01, I believe).
The top of the canister looks like this one:
Old 06-19-2018, 08:42 AM   #5
You took a picture of the fuel filter cap. Is that what you want?
The oil filter numbers for baldwin filters are
Dodge trucks - BT7349
Medium duty - B7177
Old 06-19-2018, 08:43 AM   #6
The oil filter will be forward and below the turbo on the passenger side of the bus.
Old 06-19-2018, 02:18 PM   #7
Duh.
I was tired when I asked the original question.
I am interested in the fuel filter.
The oil filter (at least on my engine) is a spin-on type and I was able to pull the number off ths side of the filter.
The fuel filter is a cartridge type and I'm not sure if a 2002 Freightliner Bus Cummins 5.9 fuel filter is the same as every other 2002 Cummins 5.9 filter.
Apologies for making extra work for you all -
Old 06-19-2018, 03:57 PM   #8
Fuel filters are the same between the pickup and a bus.
Baldwin # PF7977
Old 01-22-2021, 07:14 PM   #9
Year: N/A
Chassis: N/A
Engine: N/A
Would that PF7977 be the same filter for a 2001 24 Valve Cummins 5.9? Baldwin’s filter finder is showing me a spin on type as the match for my bus, but my engine compartment looks just like the OP’s.
Disclaimer: this will be my first DIY filter change.
Ourversionoflife3 is offline   Reply With Quote
Old 01-22-2021, 08:48 PM   #10
s2mikon's Avatar
Engine: Cummins 8.3
Don't forget fleetguard. It is official OEM filtration for Cummins.
s2mikon is offline   Reply With Quote
Old 01-22-2021, 09:50 PM   #11
ISAF2009's Avatar
Coachwork: Collins
Chassis: Bantam
Engine: International T444
Rated Cap: 16?
And don’t forget donaldson is better than fleetgard
ISAF2009 is offline   Reply With Quote
Old 01-25-2021, 08:56 AM   #12
Fuel filter or oil filter?
The pf7977 is a fuel filter, and it goes in the housing that's pictured a few posts above. The oil filter is a cartridge type and is down and forward of the turbo.
The bus will have a fuel filter and a water separator towards the back. Maybe that's the cartridge filter you're looking at?
